sticking tach when hot
My tach is sticking when the car sits outside in heat. Once the car cools off it starts working again. I read flipping the lens may fix the issue. I can only pull the tach out about an inch or two before it hits the wheel column. Does the outer bezel twist off? Anyone know how to flip the glass quickly without removing the steering wheel and column cover? Thanks. Brian
Old 07-12-2014, 04:57 PM
Ambitious Outsider
sabeo.m's Avatar
Brian, the room between the wheel and tach as you know is limited, the best way to remove the gauge is to remove the steering wheel. I personally would not recommend removing the glass lens on your tach because the bezel that holds it in place is easily damaged if you try to remove it with a flat head screw driver etc... think of it as opening a can, that bezel will never be the same. gauge repair professionals such as North Hollywood Speedometer can easily fix your problem. I got my spedo fixed by them, they are top notch. hope this helps.
1988 3.2 Cab
2005 997.1 C2S
Old 07-12-2014, 05:13 PM
Home of the Whopper
What year car?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 07-13-2014, 07:30 AM
Send a message via AIM to fintstone
Might be a CDI problem.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-13-2014, 08:24 AM
1982. Seems like needle it hitting glass once the car heats up. Of you tap the glass the needle will move. After driving and cooling the car down it will start working again. Always works when car is cool and in garage.
Old 07-13-2014, 10:41 AM
I searched here and rennlist and saw someone else had same issue. They said they flipped the glass. I pulled the tach out as far as poss, but wasn't sure how to get the front off.
Old 07-13-2014, 10:43 AM
RETIRED
Joe Bob's Avatar
Best to have it rebuilt by a speedo/tach shop. Too easy to booger up the bezel with out the right tools or expertise.
I had my speedo done due to a back plastic gear. $110 and an hour of wait. Or you can ship it.
You can google speedo shops n your area. Not rocket science.
2012 ML350 3.0 Turbo Diesel
Old 07-13-2014, 11:45 AM
Anyone know of a shop in Ct that may do this on the spot?
Old 07-13-2014, 01:43 PM
Ambitious Outsider
sabeo.m's Avatar
Like the guy's stated above, just contact either of these places. don't waste your time anywhere else.
North Hollywood Speedometer and Clock Company. Serving your gauge needs since 1955. VDO, Porsche, Mercedes, BMW, Volkswagen, Veigel, Veglia
Palo Alto Speedometer: Repair, Restoration, and Sales of Automobile Gauges
1988 3.2 Cab
2005 997.1 C2S
Old 07-13-2014, 04:31 PM
