John - how about you get someone to look at your digital levels while you put more and more of your own weight out on the end? Just to get that qualitative look before you start quantifying.
Should give you an idea of how things are going, though the question you raise is a good one, since you have a fulcrum in the middle of chassis. |
It does not matter where the supports are, torque applied to chassis will result in the same rotation about the centroid axis.
Firstly, we assume the chassis is close enough to call bilaterally symmetric (left and right are mirrored). Now, a lever arm of length L (from the center of the chassis to the weight) with weight W at the end is added. You have two mounting points for the lever on the chassis, and in this case the mounting points are also bilaterally symmetric. They are separated by a distance D (so the total length of your beam is L+D/2). This is a simple statics problem. We want the sum of the forces and the sum of the moments acting on the lever to be zero. We have a moment about the end of the lever (at the chassis centerline) L x W and a force W. Therefore, the two reaction forces at the chassis (call them R1 for the left side and R2 for the right) must cancel the applied force and moment. Now, so that I only need to type scalars we assume that a tension force in the bolt is a positive force, and a positive moment is one that turns the end of the lever towards the ground. R1 + R2 = W LW = R1*D/2 - R2*D/2 Now, some algebra R2 = W - R1 LW = (R1-R2)*D/2 LW = (R1-(W-R1))*D/2 LW = (R1-W+R1)*D/2 LW = 2*R1*D/2 - W*D/2 LW + W*D/2 = R2*D W*(L/D+0.5) = R1 This is a positive quantity as I have defined my vectors, so the left side bolt is in tension with a force significantly greater than the applied weight R2 = W-R1 R1 > W, therefore R2 is negative and the right side bolted joint is in compression. The bolt on the side where the weight is is doing most of the work. There are quicker ways to get this answer but this is a little more to the book. |
Or you can rent time on one. Morse Measurements |
The reinforcing cross member is held to the chassis with an M12-8.8 bolt. The first 8 indicates that the tensile strength of the steel is 800 Newtons per square millimeter. That's 4568 psi, or 20,340 pounds tensile strength.
So I don't think you will break the bolt. |
A little humor!
However, 800 MPa is 116,000 psi. 6061-T6 aluminum is around 30 ksi (30,000 psi). 4130 steel (normalized) is about 63 ksi. 4.5 ksi is about the strength of cheese :). The minor diameter of an M12 bolt is 9.6 mm minimum, which gives an area of 72.4mm^2, corresponding to an ultimate tensile load of 13,476 pounds. You want to stay well clear of yield however, which means more like 6,500 pounds. |
I knew I should have found one of those charts which shows strength by bolt size and grade directly, which would have kept me from overlooking the minor diameter. And maybe kept me from confusing UTS with the elastic limit.
But 200 pounds (a guy sitting on the lever) would need 32.5 feet to apply a force of 6,500 lbs, would it not?
A lot of force may be necessary. Remember the photo, in Puhn I think, of a bunch of guys standing on the end of a rather long lever to do this kind of measurement? |
Hi guys,
Do keep discussing, just letting you know im away on holiday without access to the car for 10 days. I will resume next saturday. Regarding the discussion on the steering rack bolts, isnt it a bit of a moot point? If it takes more force to twist the chassis than the steering rack bolts can withstand, and the bolts didnt break or pull before, then the car wasnt being subjected to enough twisting force for it to do so? So it doesnt matter? I guess it matters if my experiment subjects the car to more force than it encounters while driving and i were to break something. But that is an interesting question for me...if i have to subject the car to so much force that it exceeds normal use to get a measurable deflection then my results dont really matter for the purposes of seeing if my chassis mods impact handling? |
The rack mount does not experience much force in tension or compression during operation but does react lateral loading. Its design was probably based upon loads induced by bumping a curb or bouncing through a chuck hole and not from normal loads due to tire friction with the road such as from braking or cornering. The large bolt is simply large due to the requirement of the lug welded into the chassis needing enough shear strength for the lateral loads. As such, the lug is probably adequate for reasonable tension/compression loading per your requirements.
Based upon your setup I calculate:
Before I left I did bolt the crossbar back on and removed the ruler/placed a bolt on the end of the lever bar so I can just stack the weights on the end without them slipping off. I am going to take some collective advice here and; - I took the straps off the torsion bars and will hook the body directly to the lift arms - no bushings there. - Will use the bar bolted to the steering member bolts only for loading with a bunch more brake discs. - Will measure the change in angle across the rack rather than the change in height of the end of the bar Still not intending this to be lab-level data but I am listening to suggestions here. I als realize earlier I used the term "gravity-based" in reference to my dial indicators. What I should have said is that they are not spring-loaded. I have typically used them in a vertical, upright position such that gravity pulls the measuring pin down rather than any spring. |
Sherwood |
Yep. One I got from Pelican about 10 years ago when I did my first engine build. I forget where I got the other.
Maybe they are just broken... |
Forgot to add deflection at end of angle due to chassis twist which is an additional 0.06". Note that deflection of angle is 2 1/4" and deflection due to chassis twist is 1/16"; therefore, the angle as a loading beam is too limber and is close to yielding/buckling already.
Recommendations:
Dial indicators will record movement at the strapped mounting points as twist which is an error. Also, if dial indicators are not isolated from the supporting structure then they will move with the supports which is an error, they must be mounted to the shop floor to help assure they are as isolated as possible from motion of the chassis and its supports. |
Paul
His goal is not to that level of precision. For the stiffer beam suggested he'd have to conjure up a way of mounting the beam. With horizontal bolting he'd need to weld a small tube in to hold the horizontal bolt to replace the strength lost by drilling (though it could be done in the neutral axis to reduce that effect). That bolt could be larger than stock so its max shear would approach max tensile in the current arrangement. And he'd have to weld up some kind of fitting which would bolt into the stock location, and then stick down on both sides of the beam for the cross bolt. He has said he doesn't want to come up with floor stands for dial indicators. I am pretty sure he isn't going to want to install something on his garage floor for a one off experiment, and getting a pull out strength for some kind of drill a hole and insert a fastener system may not even be possible, as those are usually set for shear. I was happy enough using old 1/16" bolts climbing the Nose of El Cap, but I was very careful not to place an outward pull on them 30 years ago. And won't digital levels, placed as suggested, be about as good as dial indicators? Perhaps we are not concerned with deflections of less than 0.1 degrees? Yes, given the fairly modest weights he proposes using, or even just 200 lbs of largish male, if he could be very precise then extrapolation would be more valid, I think. The levels will compensate for the non-rigid attachment at the rear, won't they? Wasn't that your idea earlier? What he may prove to himself is that the chassis deflection he records is so far down in the noise that it won't tell him if various strengthening measures he anticipates taking are doing much. But it looks like a worthwhile endeavor, and he's pretty much got it all set up. Nothing much lost if his angle arm buckles. |
Right.
| All times are GMT -8. The time now is 04:47 AM. |
