Block heater ducts on early 911's for more engine cooling
My 73 oil temps border 250f on long drives when ambient is around 90f. Everything is in good tune and I don't have vacuum leaks/retarded timing/etc.
Was thinking of capping the heater ducts either underneath or underhood in the Summer months to force more air around the motor and through the oil cooler.
Has anyone done this with favorable results?
1973.5 911T ——-1974 914/1.8
Old 08-24-2020, 07:56 PM
skinnerd's Avatar
Not sure your temps should be that high on a normal healthy engine. Get your temp gauge checked for accuracy, etc. Has your engine always run this hot? Do you have an aux cooler in the passenger side front wheel well? Others will climb in I'm sure, but something sounds amiss.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 08-24-2020, 09:33 PM
The airflow through the heat exchangers cools them. Take that away and they radiate more heat. Try a larger SC crank pulley for faster fan speed. Even faster with a later fan with a smaller pulley.
206 637 4071
Old 08-25-2020, 06:54 AM
Vintage Owner
Jack Stands's Avatar
I’d think you’d have to switch to headers to increase cooling air flow under the engine if you block off the heater ducts. However, you shouldn’t be running that hot with a 2.4 if running correctly - maybe verify the gauge is correct (the boiling water test). Have you considered a front oil cooler if you want to cool the engine down?
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 08-25-2020, 07:42 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
The temp sender is on your crankcase, oil is a heat transfer fluid(and lubricant), if it’s too hot, you need more heat rejection surfaces, ie oil coolers. The thermostat is also a wear item, insure it opens completely. If it’s not opening completely it doesn’t matter how many coolers you have or don’t have.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-25-2020, 07:51 AM
Home of the Whopper
Mouse nest on top of cylinders!
Peek through the fan and see if any junk is in there.
Old 08-25-2020, 09:40 AM
+1 This is really common. Also, a nest can block air flow to the engine-mounted oil cooler.
Old 08-25-2020, 11:02 AM
