Len 911's Avatar
aftermarket charcoal canister
I wanted to know if there is an aftermarket charcoal canister that I can use on my 85 3.2 ...someone has changed the original out and it has BMW label on it and it is rusty. I would like to replace it any suggestions would be great. Also is this a vacuum canister, If so this might be my problem.
Thank You
Len
Old 03-23-2014, 05:05 AM
faverymi's Avatar
canister
I can give you mine.
Out of an 80s carrera.
I will never use it.
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 03-23-2014, 05:08 AM
Len 911's Avatar
as long as it works I'll take it. do.. I would still like to know if there is an aftermarket one that will work.
Thank you faverymi
I will send you my info in a PM.
Old 03-23-2014, 05:28 AM
non-whiner
mreid's Avatar
There probably is, but most car builders (replicas, kits, etc.) use a large canister fuel filter and replace the filter element with activated charcoal bought at a pet store for use in fish tank filters. Works great!
Here's a perfect example:
http://www.summitracing.com/parts/sum-g1507/overview/
"Too much is just enough."
Old 03-23-2014, 05:43 AM
Len 911's Avatar
Wanted to say thank you faverymi, I just received the filter today, It is going to be installed tonight, Thank you again, I hope to return the favor to you or someone else that is in need.
Len
Old 03-28-2014, 11:16 AM
Is this an aftermarket replacment for 911 charcoal canister
Old 07-13-2014, 05:17 PM
canister
Is this what you are looking for?
Old 07-13-2014, 07:36 PM
