cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
strange oil leak in 73 911
I have a leak where I least expected it. I initially thought the distributor seal was leaking but it's the bolt to the right (in the fan housing). I took the nut off, replaced it with a new nylon nut and gooped some Curel T on the mating surface. no luck, if anything it's worse.
Anyone else had a leak from here? I did not put any of the Curel T on the threads (between the nut and bolt). Is this the next attempt? Is Curel T the right stuff?
Thanks as always,
Chris
73 911 E
Old 07-14-2014, 09:41 AM
cmcfaul's Avatar
Should be an easy one for you Sr Wrenches.
Old 07-14-2014, 12:25 PM
