That comment was for dashes that are repaired but NOT re-covered, simply painted.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
I've not heard good things about leather on dashboards. Supposedly the expansion and contraction is an issue. But then I'm not sure how the leather in those cases was applied. Perhaps it was only attached in limited areas and left to float otherwise. In the case of my dash, the vinyl skin is fully attached with one exception --- just the lip of the console floats. Because it is tightly pulled under, I don't think expansion will be a problem here.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 07-17-2014 at 10:12 AM.. Reason: Clarity |
No offense was meant 1990C4S. If the text bothers you, you can be sure I'll gladly edit it out. PM me on this.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Project looks good.
Jim 1987 Carrera 2002 BMW 525ti 1997 Buell Cyclone cafe project 1998 Buell S1W: "Angriest motorcycle I've ever ridden." |
Fill and re-cover it should last a long time. Patch and paint is only a temporary fix.
Tossing in dryer requires first move be a compound curve. In the case of our 911 dashboards... the compounds are well down the line from 1st move. Still... compliments for the add.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 07-18-2014 at 11:17 PM.. |
Boyt911SC / Tony asked me to share the sequence for attaching the vinyl. Those drawings were in this location but have been updated and reposted below.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 07-19-2014 at 12:18 AM.. Reason: Update drawings |
Perfect Illustrations.........
Karl,
These illustrations are perfect and super helpful. After reading and following your procedures, I had the impression that you did the 1-2-3-4 back (flat) areas before doing the curved (domed) area by the driver side. So you did area #1 (back to front), then area #2 (back to front)......etc. PM sent. Thanks. Tony |
Attachment sequence.
Entire skin is attached to the board with two exceptions: 1) The waterfall of vinyl along the entire front edge of the top deck including vent areas. And 2) the lip section of the console (shown in orange below.) Rather than epoxy the console's lip, the vinyl in the lip area is stretch-wrapped around the lip and glued underneath in stages 27-32. This is done to avoid possible issues in this area --- the curves around the lip make a smooth & even application of epoxy difficult. ![]() ![]() ![]() Below are a few reference images to the areas above... Stage 1 ![]() Stage 8 ![]() Stage 11 ![]() Stage 15. There is another push back of the vinyl in this area which has yet to be made as stage 16.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 07-27-2014 at 05:42 AM.. Reason: Clarity |
1. masking tape is removed and the vinyl is laid over working area 2. on top deck, crevice is pushed in with tubing 3. vinyl surface is lightly rubbed to force epoxy gel slightly into backing 4. on top deck, tube is held in crevice (11 minutes from when a batch of 5-minute epoxy is mixed.)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 07-20-2014 at 05:15 AM.. Reason: Simplified |
Discseven,
THANKS FOR THE WORK DESCRIBING YOUR PROGRESS! |
My pleasure. The fact is, I've learned so much from this forum... whenever I have an opportunity to share & give back, I do. (Great "Oil Rig" in your garage Baloo... that's a piece of history!)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 08-08-2014 at 04:06 AM.. |
Dashboard surface temp... Miami... after 30 minutes parked in direct sunlight:
Karl - how is that vinyl holding up after some Florida heat cycles? Which specific vinyl product did you use? I am getting a sample of Allsport's "4-way stretch" product, which is $28/yd:
AllSport 4-WAY Stretch Vinyl |
Great write up! Does anyone know if this process would be compatible with Alcantara?
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
aircooled addict
I have always wanted to use vacuum bags to help hold the material onto the surface while the adhesive dried. This way the atmosphere is pushing uniformly on the entire surface. I havent looked, but I think there are 'spacebags' large enough that this might be an option. Has anyone tried it?
I know this is how they make strong glue joints for wood. It provides much more pressure than a clamp, and more evenly. |
Ferri... Vinyl has held up without change since installation. Once in a while it gets some ArmorAll but would consider this "minimal maintenance." Is automotive-grade vinyl, 4 way stretchy, black textured surface (matches Porsche text quite well) with a woven material backing. If using Gel Epoxy, suggest woven material backing very important as this woven backing is what gel sinks into. I'd not advise using a NON-backed vinyl as ANY imperfection will be transmitted to the visible surface. With a woven backing, the gel grabs the backing leaving the vinyl to "float." (Gel applied to dashboard is no more than a "skim coat." Too much gel and the vinyl turns into a water bed! Much testing was done to get this procedure correct.)
One drop of gel on the fingers and then contact to the face side of Alcantara and I believe it's game over. I think it could be done.
The idea with gel is to "float" the vinyl by applying only very light pressure to the vinyl's surface once an area is glued. Technically the goal is for the woven backing to connect with the gel... not the vinyl. This "float" of the vinyl allows some tolerance for imperfections.
Pardon for the very late replies guys. Been submerged in a 930 restoration and am guilty of working with my tunnel vision on full tilt.
