| Discseven |
10-20-2018 02:56 PM |
Been three years since doing this dash. Status = no issues have occurred with vinyl material or gel adhesive. There's also no warping of dash. Were I to do again, would take same path with one exception... center AC vent. Would take 3/32" off bottom and one side inside porthole in dash for this vent. This would allow vent unit to insert fully and claw-grab into dash as it is designed to (so screw mod would be avoided.) Tested leather using same procedure. Vinyl is easier material to apply due to backing---vinyl's cloth woven backing is perfect whereas leather's backing is not. Am sure leather could be applied with same result as vinyl but "practice" is needed. While not 100% sure, I believe leather tends to shrink and expand more than automotive vinyl depending on cabin heat/cold.
