-   -   A/C Help please! Search didn't help me. (http://forums.pelicanparts.com/porsche-911-technical-forum/820915-c-help-please-search-didnt-help-me.html)
Rodek 07-15-2014 07:27 PM
Hi Folks. I tried the search feature first and couldn't find what I'm looking for. This is where you come in. You see, I have a leak in an air conditioning hose. I can actually see the leak. It's located just forward of the sway bar. The hose is red in color and goes from the high side of the compressor all the way to the smuggler's box. My car is a 78 SC and only has a rear mounted condenser. My question is: can someone please tell me where to get said hose? It's hot here in Alabama! Also, feel free to school me on anything A/C related. :confused:
targa80 07-15-2014 08:02 PM
The line from the evaporator (Smugglers box) to the compressor is not the high side it is the low suction side. Pelican has the part, P/N 911-573-149-02-OEM for $163.
This is the AC block diagram without the front condenser.
http://forums.pelicanparts.com/uploa...1405482030.jpg
This is the drawing associated with the above part number.
http://forums.pelicanparts.com/uploa...1405482145.jpg
I have been reworking my AC system in my 80SC. All of my factory hoses are black and are still fully functional. There are discussions on the board about barrier vs. non-barrier (OEM) hoses and it is recommended to replace the no-barrier with barrier hoses. If you want the barrier hoses you will need to go the aftermarket route. In my own case I cannot justify the cost ~$500 to replace the complete set of non-barrier hoses. I am aware that they leak over time due to design and I will live with the loss in efficiency of the system. You mention yours is RED, I'm no expert but I would guess that it is not original to the car.
Rodek 07-15-2014 08:23 PM
Thank you for the quick response! Amazing! I also appreciate the parts break down and hose explanation. I'll see about getting that hose from the site ASAP. I'm not sure about the red hose. I'm only the second owner of the car so maybe the original owner had it replaced at some point. It does however look really old...outer jacket frayed in a spot or two as well. Maybe there was a change between 78-80 possibly?
T77911S 07-16-2014 04:09 AM
check locally. there may be a shop that can make a new one.
GH85Carrera 07-16-2014 04:42 AM
The cheapest and easiest thing is to remove the old hose and take it to a AC repair shop. They can replace the rubber hose or make you a all new hose of the proper size and connections. Be sure to tell them it is a metric fitting but they should know that anyway.
Most likely they will want to reuse your metal ends and just replace the rubber hose.
And I can't imagine the red hose was original. Likely some previous owner "fix" that was cheap and now but not the proper fix.
RedCoupe 07-16-2014 05:17 AM
If you remove the hose yourself, be sure to cap the open fittings when you remove the old hose if you are going to leave them open for any length of time. A new receiver-drier is also probably in order when you go back together. There is a lot of information about Porsche A/C available here on this forum and elsewhere.
Rodek 07-16-2014 07:32 AM
Thanks for the replies folks. I'll check around locally to see if anyone makes the hoses. I will also get a new receiver drier as well. I'll also read as much as I can on the forums to learn more about the A/C system. I'd like to do this myself so I think knowledge will be key. FYI>>> I checked with the PO this morning. He said the red hose was a replacement done in the early 90's. I'm going back to the OEM black.
GH85Carrera 07-16-2014 07:47 AM
The receiver dryer is absolutely something to replace.
See if the place making the hoses has fitted caps for the hoses or fittings. If not rig up something to keep dirt and gunk out of the hose. Once everything is hooked back up a good flush with AC flush would be a good idea if the system has been open or if you don't know the condition of things.
Read the threads on Pelican about AC. When you get to the arguments just skip past.
Listen to the folks that actually live and drive their 911 in hot climates or own a successful and established AC business. If you see advice that just sound stupid, it probably is.
Pull a vacuum for a long time, like an hour. Let it sit overnight and see if that holds. A nitrogen pressure rig is even better but a little expensive.
AC is repair is not difficult, just a little scary at first.
Rodek 07-16-2014 10:19 AM
Thank you for the wonderful advice. I've spent part of the day reading about a/c systems and this does sound like something I'm able to do. Like you said, it's a bit scary to me now but I think after reading everything here and getting the right parts, I'll be on my way to cool driving. This thread and all the posters in it have been extremely helpful thus far and I really appreciate it.
Bob Kontak 07-16-2014 11:01 AM
I like this guy on youtube. He gives three or four problem scenarios and solutions from different gauge readings.
Not a 911 but the concepts are the same.
https://www.youtube.com/watch?v=80jSH8VQZms
He has lots of other videos on car topics. He's a hoot.
Rodek 07-16-2014 11:07 AM
LOL! You're right. That guy is a hoot! That gauge set is very affordable and after watching the video, I bet I could check my own pressures now. Thank you!
GH85Carrera 07-16-2014 11:24 AM
You will need to borrow, rent or buy a good vacuum pump. I would personally not get a Harbor Freight vacuum pump or something super cheap. Some auto parts stores will loan them some rent them. The first step in getting a good AC charge is a good vacuum.
Rodek 07-16-2014 11:28 AM
I have an Uncle that has a vacuum. Once I get the hose, receiver dryer (and apparently an in-line fuse for the condenser fan motor) taken care of, I'll have him help me pull vacuum on the system and get it recharged correctly. He even sounds interested in helping me with the rest of the work.
GH85Carrera 07-16-2014 11:33 AM
That is 1/2 the battle, if you can find someone that has done it before. Good luck. Enjoy learning about AC. I had a great time doing my AC upgrade. Once you get it tweaked and running you will find the stock AC in air cooled 911s is weak.
I contacted Griffith's and ordered the dual condenser setup. That made a big difference in cold air. It was not cheap but it is top quality.
Rodek 07-16-2014 11:42 AM
Wow. Sounds like I'll have my work cut out. I am actually pretty excited about learning A/C. Just from this thread alone there has been a treasure trove of new to me info which has me excited. I suppose that's what makes this forum such a great place. :)
I'll research Griffith's and see what they have to offer. Thanks for the heads up!
Rodek 07-16-2014 03:48 PM
I thought of another question. Is it a good idea to remove the AC compressor fan belt until I'm able to repair the AC system? I'm not sure if I can cause damage to the compressor as it's "freewheeling" back there with the AC switch off.
Bob Kontak 07-16-2014 05:44 PM
Not a problem. It was built to freewheel all winter.
targa80 07-16-2014 06:07 PM
Just don't try to turn the A/C on until you fix the problem.
Rodek 07-16-2014 06:27 PM
Thanks guys! I'll leave the belt on until I begin repairs.
kuehl 07-17-2014 05:46 AM
Originally Posted by Rodek (Post 8166171)
The hose is red in color and goes from the high(?) side of the compressor all the way to the smuggler's box. My car is a 78 SC and only has a rear mounted condenser.
Red fabric wrapped around black rubber was common 78 and earlier. It was OE however you did not get to choose your color.
78 and earlier most common was the Behr factory system.
If the hose on the compressor is on the "high side" it would either lead to the front condenser on a two condenser system or the drier on deck lid condenser only system, drier would be in the LH front fender.
Deck Lid Cond to Front Cond
http://forums.pelicanparts.com/uploa...1405604050.gif
Deck Lid Cond to Drier (Behr system)
http://forums.pelicanparts.com/uploa...1405604129.gif
Evaporator outlet to Compressor Suction Side (Behr system);
hose runs under splash pan under front cross member and into Smugglers Box
http://forums.pelicanparts.com/uploa...1405604388.gif
If you have a VPC system, the drier would be in the RH front fender.
Deck Lid Condenser to Drier (VPC system);
http://forums.pelicanparts.com/uploa...1405604721.gif
Unplug the electrical wire at the compressor clutch until you have time to fix the issue.
And, check your other hoses under the car; very common to find a hose crushed from improper vehicle lift point placements.
AJ's 911 07-31-2014 09:44 AM
Sorry to hijack this thread, but I was also looking to replace a leaky long hose (driver side) and wound up ordering the rear condenser to front condensor hose. In my discussions with the PP guys, this was the part needed for my 84 911. It was also my understanding that the receiver drier hoses either connects to the front condenser or evap. Did I get this wrong?
GH85Carrera 07-31-2014 10:57 AM
As I recall....
On a stock system the receiver-dryer is in the back of the drivers side front fender. The hose from the back condenser connects to the receiver-dryer and a different hose continues the journey on to the front condenser. Then it goes to the evaporator. It would likely be smart to replace the receiver dryer while you have the system open if you don't know how old it is.
kuehl 07-31-2014 11:37 AM
On a stock Left Hand Drive 911 with deck lid condenser and front condenser, Behr system, its easier to imagine what connects to what if you follow the refrigerant flow starting at the compressor outlet:
1970-1983 911, 2 Condenser, flare fittings
Compressor to Deck Lid Condenser - 91157315002
Deck Lid Condenser to Front Condenser - 91157315303
Front Condenser to Drier - 91157315402
Drier to Expansion Valve - 91157315202
Evaporator to Compressor - 91157314902
for a single condenser system you delete 91157315402 and you
replace 91157315303 with deck lid condenser to drier 91157315100
1984-1989 911, 2 Condenser, o-ring fittings
Compressor to Deck Lid Condenser - 91157315003
Deck Lid Condenser to Front Condenser - 91157315305
Front Condenser to Drier - 91157315403
Drier to Expansion Valve - 91157315203
Evaporator to Compressor - 91157314903
There were a few systems other than the factory Behr system in the early 911's prior to 1978, for example VPC , in which case part numbers will be different and hose routing is different for a few of the hoses.
Feel free to PM if you need assistance.
AJ's 911 07-31-2014 11:41 AM
I spoke again with the PP guys and they pointed me to the PET Illustration on Section 8 Main Group
As you can see below, hose number 16 from the PET illustration shows a direct line between the rear condenser and front condenser. Part number 911-573-153-05
http://forums.pelicanparts.com/uploa...1406835033.gif
The illustration below shows the 2 hoses coming out of the receiver/drier which points to the front condenser and evaporator.
http://forums.pelicanparts.com/uploa...1406835414.gif
DRACO A5OG 07-31-2014 12:27 PM
Your 84 is set up like mine.
From the front condensor, the hose goes to the dryer in the driver side fender then routes down along the side rocker and up the rear wheel well then up the cavity between engine bay and chassis then to the rear condensor then to the compressor. So there are two short hoses and one long one.
AJ's 911 07-31-2014 01:45 PM
Draco, sorry to be dense about this topic, but now I am confused. What Mr Kuehl and Pelican Parts guys told me are consistent. I need a long hose to connect from rear condenser to front condenser. You and 85Carrera seem to imply that I need a hose frrom receiver/drier to rear condenser.
Incidentally our host only sells 2 long hoses:
1. Evap to compressor
2. rear-to-front condenser
and 3 short hoses:
1. front condenser to receiver/drier
2. receiver/drier to evap (expansion valve)
3. compressor to rear condenser
AJ's 911 08-07-2014 09:04 AM
So just an update, the long A/C hose which goes from front condenser to rear lid condenser was the right part for my 84 Carrera 3.2.
I decided to try and replace this on my own and boy was it a "PITA". I actually cut the old hose closer to the rear wheel with the "bright idea" that I would tape the new hose end to the old hose and guide it out to the engine bay by pulling on the old hose from the rear condenser. This thing was not budging at all.
I finally brought it to my mechanic and he told me that there are hard old lines that is pinching the hose so he had to use a pry bar to make room and pull the old hose out and snake the new one in.
Total time to install this long hose and attach a new receiver/drier was 2.5 hours.
I would be curious to hear if anyone else has attempted this on their own and how long it took to do it.
kuehl 08-07-2014 09:46 AM
Pry bar? lol
"Normally", for entrance into the engine compartment you just cut the old hose as close as you can near the rear shock tower (if its giving you a hard time) and yank it down from the bottom near the heater box. For up by the water bottle, ditto, cut it by the bottle and pull it down near the front condenser.
To install the new hose in engine compartment: you go up by the heater box and if it stops when you are pushing its either hitting the engine insulation or a 'hard' metal fuel line (no crow bar needed).
To get the other end for the front condenser, you slip it over the top of the water bottle adjacent to the inner fender wall, then go underneath and look up (safety glasses and drop light) and snag the end with a coat hanger and pull it down.
Done that way every day, including on an 84 sitting here now.
GH85Carrera 08-07-2014 10:18 AM
and 3 short hoses:
Glad you got the right part. It has been several years since I did my AC system and my memory was faulty. Kuehl had it right of course. He does this all the time and sells the parts.
Swapping the hoses is a dirty and pain in the rear job. It is nice to have a leak free system and worth the effort.
AJ's 911 08-07-2014 11:58 AM
Mr Kuehl, thanks for the tips. I am sure this is documented in the Griffith kit, but it is good to know for the rest of us for next time.
The "pry bar" thing was just as surprising to me and my immediate reaction is "what potential harm did that do?" I might have mixed up the hard fuel line for the oil line so my bad.
I appreciate everyone's help!
