-   -   Another Front Condensor Fan Bites the Dust (http://forums.pelicanparts.com/porsche-911-technical-forum/820924-another-front-condensor-fan-bites-dust.html)
targa80 07-15-2014 09:30 PM
I have been testing the AC system for leaks before I reinstall the system in the car.
http://forums.pelicanparts.com/uploa...1405483841.jpg
The system holds a solid vacuum and I have ordered a new Dryer to install once the system is back in the car. The next step was to check the two fans (Evaporator and front Condenser) . The Evaporator fan needed a little lube on the two bearings since it was hard to turn initially. The Front condenser fan was frozen and when I took it apart this is what I found.
The brush mountings melted to the commutator
http://forums.pelicanparts.com/uploa...1405484315.jpg
You can see one of the Brushes in the picture.
http://forums.pelicanparts.com/uploa...1405484420.jpg
Looking at the AC circuit, it is protected with a 20 amp fuse in slot 20 and I don't remember it being blown. As an added precaution, I will be installing an in-line fuse with a lower amperage rating for the new motor.
Rodek 07-15-2014 10:24 PM
Sorry to hear about the motor biting the dust and I hope your new motor gives you years of trouble free A\C. BTW, nice tip on the fuse. I think I'll do the same once I get that hose taken care of.
shadowjack1 07-16-2014 04:45 AM
As I recall that new inline fuse should 7.5 amp.
GH85Carrera 07-16-2014 05:59 AM
That fan is the cause of a LOT of 911 fires. There is a Porsche part number for a inline fuse that is part of a recall.
Dueller 07-16-2014 07:19 AM
I think I have two of those motors if you need one. One is NIB if I recall. Let me know.
cabmandone 07-16-2014 07:35 AM
Wow! 20 amp? Is that what is called for in that circuit? It seems like the suggestion of a lower amperage fuse inline is a very good idea.
Barrpete 07-16-2014 08:17 AM
+1, 7.5 amp is correct.
MConn 07-16-2014 09:56 AM
If you don't want to cut your harness, the Porsche part number for the inline fuse is 911612077 - kind of pricey
I think I had to use a 10 amp because of starting current, but I'm using a footwell blower motor.
Mike
ganun 07-16-2014 10:35 AM
BTW, a cool idea to lay it all out like you did and pull a vacuum. Now all you need is to hook the comp to a 5 hp elec motor and put the evap in its box ........
ganun 07-16-2014 10:38 AM
I forgot to mention that the evap blower should be replaced if it was hanging up, even if you freed it up and it rotated better it still won`t run at the revs as a new one.
86 911 Targa 07-16-2014 10:41 AM
Fuse kit.
HOPE THIS HELPS.
http://forums.pelicanparts.com/uploa...1405532500.jpg
Rodek 07-16-2014 11:41 AM
Alright, since I'm still learning my 911 and it's A/C system, I have to ask. Where is this inline fuse supposed to be located? The smuggler's box or the in-trunk fuse holder or....somewhere else???
targa80 07-16-2014 12:46 PM
Originally Posted by Rodek (Post 8167079)
Alright, since I'm still learning my 911 and it's A/C system, I have to ask. Where is this in-line fuse supposed to be located? The smuggler's box or the in-trunk fuse holder or....somewhere else???
rodek,
if i remember correctly you said you did not have the front condenser with the fan. the fan on the evaporator in the smugglers box is protected from the elements of outside air on the other hand the front fan draws air directly from the environment and is drastically effected over time. i would not go with a separate fuse in-line for the evaporator fan but that's just my thought process, others may disagree. you are lucky to have an uncle with the vacuum pump and i bet he has the gages too. if not i bought the gages anf the 2.5cfm vacuum pump from my local harbor freight. yes, they are made in china and they are cheap but for a diy shady tree mechanic they fit the bill for my limited use. did i mention that they are really cheap.
targa80 07-16-2014 12:50 PM
looking at the schematic for the a/c circuit fuse 20 is rated at 25 amps, understand this provides power to all of the electrical elements of the a/c system.
targa80 07-16-2014 12:52 PM
jim,
thanks for the offer but i have one on the way from our host.
Rodek 07-16-2014 01:16 PM
Originally Posted by targa80 (Post 8167224)
rodek,
Thanks for clarifying! I don't have a front condenser so I guess the inline fuse doesn't apply. Yes, I'm glad my uncle has the vacuum and you're probably right about him having the gages. I may go ahead and pick my own set up at harbor freight just to have them around for my other vehicles too. It's not a bad idea to pick up that vacuum I suppose as well.
86 911 Targa 07-17-2014 09:29 AM
This fuse holder located on the fan harness
was added on the M/Y 88-89 on a Porsche service bulletin.
Fusing for the 3.2 cars was not Porsche's finest hour.
Check my threads/posts for added fuses and relays.
Or, pm me.
Good luck,
Gerry
Jack Stands 07-17-2014 08:43 PM
Those brushes looked a lot like mine when it stopped working. A new motor ( I think sourced from eBay), and an inline fuse and I'm good to go.
There are threads on replacing the condenser fan, just be careful removing the blower fan off the motor shaft.
Discseven 07-18-2014 08:02 AM
I had same melt down with mine.
http://forums.pelicanparts.com/uploa...1405695487.jpg
A follow up on Jacks note about removing blower... the allen screw securing blower to shaft on mine was sealed with some sort of hard wax. I'm not drilling it out in the photo below... I'm just poking the stuff with a drill bit... and it came out. The blower took some time getting off the shaft.
http://forums.pelicanparts.com/uploa...1405695696.jpg
http://forums.pelicanparts.com/uploa...1405695713.jpg
Jack Stands 07-18-2014 11:09 AM
Once you loosen the Allen head sets crew, getting the squirrel cage blower off the shaft can be a chore. As the motor is toast anyway, I found it easiest to chuck the motor housing in a vice and tighten down until the housing is distorted enough to crush the armature against the outer housing, preventing it from turning. Then by simply rotating the outer edge of the fan blades, I was able to turn the entire shaft so as to get it to break away from the commutator and electrical windings, then simply remove the shaft with the fan attached. Then, it was simple to rest the hub of the fan supported on a vice and simply tap the shaft out of the hub with a drift.
When you install the new motor and fan assembly, check the positioning of the fan in the blower housing so it doesn't hit or rub against the plastic.
Discseven 07-19-2014 01:45 AM
Nice Jack. I'll add checking to make sure the wiring is connected to spin the blower in the right direction.
http://forums.pelicanparts.com/uploa...1405759461.jpg
targa80 07-19-2014 05:47 AM
[QUOTE=Discseven;8170297]I had same melt down with mine.
[QUOTE]
The hard wax is a red locktite which prevents the screw from coming loose during operation.
Discseven 07-19-2014 06:05 AM
Thanks Pat. I thought it was a rust inhib.
tirwin 07-19-2014 06:10 AM
I recently got a new motor. I was trying to get that dang Allen screw out and the Allen wrench broke right off flush inside the screw. Talk about pissing me off!
Kidasters 07-19-2014 06:10 AM
+1 on the fuse. I installed one on my car when I re-built the front fan.
On the squirrel cage. Soak soak soak in your favorite penetrating agent. For a few days. Right at the tip of the shaft, corrosion build up won't allow you to just pull the squirrel cage off. And, the cage is delicate. After soaking, use a dremel with a small wire brush to try and clean up that tip area. Do not use a puller of any kind - you will damage it. Finally - coat the shaft with anti-seize before re-installation - just in case.
azhodge 08-12-2014 01:58 PM
anyone know where to get those dang clips that hold the two halves of the condenser fan housing together? one was missing and another one flew off into the never to be found corners of my garage...
JAR0023 08-12-2014 02:19 PM
Mike
10 amps here as well. Factory harness showed up with a 7.5 and it blew more times than not when I turned on the A/C. I bumped up to a 10 amp and that one's been in the car ever since. -J
MConn 08-13-2014 04:54 PM
Our host sells these -
Tension Spring
Mike
Chuck.H 08-14-2014 05:08 AM
I'll bet that felt good!!! I hate these dangerous, ineffective, noisy, unreliable and expensive Bosch fans that I'm slowly replacing with (inverse of all previous adjectives) GM fans.
Chuck.H
'89 TurboLookTarga, 380k miles
azhodge 08-14-2014 05:51 PM
just tried to order the 911612077 fuse kit from our sponsor. $48 dollars was bad enough, but after ordering they informed me that it is no longer stocked in the US and must come from Germany. But for a cool additional 20%. thats it for me. I will make my own for eight dollars. won't be a pretty but it will work.
