Advice on engine hoses (problem inside)
Not sure whether I'm unlucky, clumsy, or if my car is falling apart (or all three!)
I managed to finally replace my fuel accumulator and filter as below. http://i306.photobucket.com/albums/n...psefctjnms.jpg While doing the install I hit one of the hoses with my arm and it broke. It connects to the airbox and goes into the engine wall as far as I can tell. http://i306.photobucket.com/albums/n...psdae7f6a9.jpg http://i306.photobucket.com/albums/n...psc0ea9765.jpg 2 questions - first, what is it? and more importantly, do I just replace with OEM hoses or are there better quality after-market types I can use that will last longer? |
Its the vent to burn any fumes from the charcoal canister. Lots of times the canister has been unhooked or removed.
Bruce |
If you still have a charcoal canister just about any vacuum hose will work as a replacement. If you want OEM looks that cloth wrapped hose is available.
If you just plug it you will notice a gas smell that can stink up a garage. The charcoal canister is just something to keep the gas stink down. |
I had one of those EVAP hoses break near my exhaust.
I was lucky the resulting FIRE did not spread. |
You can trim it and splice it with a small piece of tubing .BUT you probably should start replacing some of the other hoses in there as a routine . They don,t last forever even if they look OK they get brittle with age.
Thanks guys. I've now researched a bit about the charcoal canister and it seems like it doesn't harm to keep it. Meanwhile, can I just plug both sides of this hose or should I leave it as it is?
If left open your air filter inhales dirty air thru it(admittedly not much) and the fuel system metering is expecting a certain quantity of fuel vapour from that source, also not much but some.. The main purpose of the evap canister is to collect fuel fumes that are evaporating either during a refuel or ,while parked .Then it purges the canister when running. As pointed out by someone above disconnecting can introduce a gas smell under the hood under some circumstances. It,s a smog control device which doesn,t use any horsepower ,only adds minimal weight and why not keep it functional.? |
It looks like your fuel lines are in better shape than the vapor hoses.
Rotten or brittle fuel hoses are a recipe for disaster. Do you carry a fire extinguisher? |
I didn't carry an extinguisher but will make sure I keep one handy from now on.. thanks for the advice |
I can help you with any hose question on the early CIS 911's. Len at Autosportengineering dot com :) |
| All times are GMT -8. The time now is 04:37 PM. |
