-   -   Key Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/82104-key-problem.html)
FranksPlace2 09-27-2002 11:19 AM
Key Problem
When I bought my '77 Targa in Feb, it came with two keys: a red key that fits the ignition and nothing else and a black key that fits the left door and nothing else. Neither of these are original Porsche keys. Both have a groove down the middle plus 2 channels (slightly wider grooves) on both sides.
I bought a black key blank from the Porsche dealer. It has a groove down the middle and one channel.
My Owners Manual (Thanks, Dennis) says the black key is the master key and the red key is the valet key (ignition & doors).
I would like to make a "master" key from my red key.
Since neither of my keys function correctly, I wonder if the this will work.
What do you suggest?
Frank
P.S. I am also reviewing Wayne's "Rekeying Porsche Locks" project.
Rot 911 09-27-2002 11:28 AM
Keep reading the rekeying locks tech article. Sounds like the locks have been changed in the past. If you rekey the red key I think all you will be able to do is use it in the ignition.
