 G50 Shift Shaft Seal R&R - Bentley Error I'm in the middle (literally) of replacing the shift shaft seal.  In the Bentley guide it says: Quote:
 Interestingly, when I pulled the rubber boot off, the old shift shaft seal pulled off with it (totally different than on a 915). I wonder if anything other than force could hold the seal to the case? More news as I finish this project - so far, so good. |
| All times are GMT -8. The time now is 01:50 AM. |
