Originally Posted by tirwin View Post
I would. Mine had the same. Can you imagine breaking those without anti-seize on them?
And...off to my FLAPS! Makes sense...any idea about how much torque to put on the lower bolts and upper nuts?
Old 07-26-2014, 10:59 AM
Hey, nice marmot.
tirwin's Avatar
I just saw that in the Bentley. Rear shock absorber to trailing arm is 125 Nm (92 ft lb). Rear shocker absorber to body (M10) is 25Nm (18 ft lb).
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-26-2014, 01:21 PM
Yep, I've got this little book from Porsche with every spec on the car. Thanks for confirming. How the heck can you get a torque wrench on the top of the shocks? Especially the right side? My engine isn't out (sighs with jealousy)? Isn't the bushing at the top of the shock supposed to act as a stop? See Porsche 911 Rear Shock Remove And Replace | RVB Precision.
Old 07-26-2014, 07:37 PM
Hey, nice marmot.
tirwin's Avatar
Hmmm... I see your point. I have a set of gear wrenches that were perfect for removal. I just put the gear wrench over the nut and then grabbed the square end of the threaded rod with a small pair of vice grips. I would use the same approach for tightening and just check it with a torque wrench using a deep socket. I dunno... I'm thinking out loud without being in front of the car.
Next week I'm on a business trip and get to stop by and pick up my re-valved shocks from Chuck Moreland. Last time I did that the TSA guy at SFO wanted to know what I was doing with a box of suspension parts. At first I thought I was headed for a body cavity search. Turns out he was just a car guy.
Old 07-26-2014, 08:40 PM
porschetub's Avatar
Originally Posted by garment View Post
Yep, less than a Jackson spent at the Freight, and the bolts are off! Thanks fellas!
Next question though - the bolts at the lower shock connection appear to be coated in copper anti-seize. Should i be re-applying here? The anti-seize appears fresh after all these years, amazing...any thoughts?
Just be aware that anti-sieze ,never-sieze,coppercoat or otherwise known as many other names can seriously affects the torque of any fastener that requires a torque value to tighten,a coating of grease (non graphite) or engine oil will not comprimise the specified torque .
If you ''cherry red'' a bolt with heat it no longer useable @ its rated tensile strength.
I personally like a lick of grease after cleaning up the thread on the bolt.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-26-2014, 11:18 PM
