Banned
sunroof only opens 1/2 way
from the files of fix 1 thing, break 2 more (I just had my motor out)...
my roof decides last weekend to stop opening fully
I hear some nominal 'crunch' when it stops
I've not worked on roofs before - is there a normal failure mode for something such as this?
Step 1 - unzip headliner?
Any insight appreciated thanks.
And here I'd just been reading the "what surprises you that it still works on your car" thread here and so many mentioned "sunroof"... of course!
Old 07-30-2014, 07:56 PM
82SuperC's Avatar
Sunroof Transmission gearbox
Check the transmission gearbox unit....the plastic gears crumbled on mine...
JB Noriel
82ChiffonSC
IG @82_901sc
Old 07-30-2014, 11:33 PM
Barrpete's Avatar
Mine did that when the screw that adjusts the height came out. Or the cable could be broken.
Here's an excellent thread on disassembly/assembly with pics.
Sunroof cable repair and new seals 87 911
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 07-31-2014, 08:12 AM
Banned
ahhhh, THANKS PETE!
Will have a look at that now!
appreciate the guidance, was kinda surprised only 1 reply and figured WTF? I'd tried searching 'sunroof' and was shocked at how little / nothing I found!
wish me luck, thanks again...
Old 07-31-2014, 08:47 AM
Barrpete's Avatar
Actually you'll be surprised how simple it is once you dig into it. Good luck.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 07-31-2014, 09:21 AM
