-   -   Indicator Light Question (http://forums.pelicanparts.com/porsche-911-technical-forum/822236-indicator-light-question.html)
Discseven 07-24-2014 02:53 PM
Have just pulled my Temp / Oil Pressure guage and found the top indicator light slot in the guage has nothing there. ('80) What's this indicator for?
http://forums.pelicanparts.com/uploa...1406238324.jpg
http://forums.pelicanparts.com/uploa...1406238486.jpg
targa80 07-24-2014 05:08 PM
What ever it was originally for has been deleted in the 1980 version that I have. I ended up using it for the factory alarm active indicator that I added with a keyless entry module.
Discseven 07-25-2014 04:14 PM
Thanks Pat. You seem confident in your answer. I'm still a bit spooked... there's taped off wiring just behind the Temp / Oil Pressure guage. I realize now that I should have taken the tape off and checked the wire color. Will do that tomorrow and post image.
http://forums.pelicanparts.com/uploa...1406329969.jpg
targa80 07-25-2014 09:12 PM
[QUOTE=Discseven;8182258]Thanks Pat. You seem confident in your answer. I'm still a bit spooked... there's taped off wiring just behind the Temp / Oil Pressure guage. I realize now that I should have taken the tape off and checked the wire color. Will do that tomorrow and post image.[QUOTE]
I have been reinstalling all of the original harnesses back into the car and each circuit has been buzzed out per the schematic. I was unable to find any lamp that was correlated to that opening. If anyone knows what it was originally for I would like to know?
catuck 07-25-2014 09:42 PM
O2 sensor? Just a guess.
porwolf 07-25-2014 11:25 PM
I found this picture of an oil pressure/temperature 911 gauge on the internet and it looks like the top indicator light is intended to be connected to the brake system?
http://forums.pelicanparts.com/uploa...1406355934.jpg
porwolf 07-25-2014 11:30 PM
Actually I got the picture from an evilbay offer. This is the back side of it, looks like 5-76 build:
http://forums.pelicanparts.com/uploa...1406356236.jpg
Discseven 07-26-2014 11:20 AM
Thanks for input guys --- and for images Porwolf. Back of guage you posted Porwolf is exactly like my '80 temp / oil pressure guage (shown below). On Porwolf's guage, it appears there's a connection at post marked #6. I have no connection on this post.
http://forums.pelicanparts.com/uploa...1406395226.jpg
The wrapped / disconnected wire I found behind the temp /oil press guage yesterday... here's wire unwrapped. It has a female spade-end and the wire's clearly suffered a partial meltdown.
http://forums.pelicanparts.com/uploa...1406396737.jpg
The origin of the "toasted" green wire is from the cabled bundle where other temp / oil pressure wires exit from (at arrow). You can also see the vacant post here. It's just under the spade of the toasted wire:
http://forums.pelicanparts.com/uploa...1406397123.jpg
With the spade on the end of the toasted green wire...and a suggestion that there is a connection at a post where my guage has a vacant post... and the toasted wire exiting a cabled bundle where other temp / oil press wires exit... the pieces of this puzzle together suggests the toasted green wire might connect to the vacant post my guage has... BUT... my guage seems to function fine with the vacant post as is.
I'm not an electrical guy so I'm not sure what to do with this. Suggestions please --- with the exception of saying "Connect the toasted wire to the vacant post and see what happens."
http://forums.pelicanparts.com/uploa...1406397715.jpg
I've searched around under the dash for a light, brake or otherwise --- thanks Porwolf for posting the "brake" photo... but nothing was found.
My thoughts --- sometimes we mess with things like this only to make matters worse. Perhaps with a working guage (at least it seems that way), I should leave well enough alone. Again... suggestions are invited. More to the point on toast, if you know exactly where this green wire goes, that would be the holly grail here!
porwolf 07-26-2014 01:11 PM
From the backside picture (not my speedo) that I posted it looks like your empty post should be a ground connection. It has that ground symbol (three horizontal lines topped by one vertical line) on the black plastic base.
As far as the melted "green wire" is concerned from my '78-'83 Bentley SC manual's electrical diagrams I take that there are 5 wires with green color connected to the oil gauge:
  1. Green/Red: Oil Pressure gauge
    2. Bllue/Green: Generator Charge Indicator Light
    3. Green/White: Oil Pressure Indicator Light
    4. Green/Black: Oil Temperature Gauge
    5. Green/White: Oil Level Indicator Gauge
I am still not positive about what the third indicator light on the top of the oil indicator gauge is for. But i do remember a discussion on the Pelican board about it in the not to distant past. I let you know when I find it.
porwolf 07-26-2014 01:36 PM
Here is the thread trying to identify all the indicator lights of the oil gauge I was thinking about. For the top indicator light it suggests being an "idiot light" having something to do with the CIS system. Maybe it does not apply to '79 or '80 SC's and is not used for those models. Maybe it's just a hold-over from earlier vintages.
http://forums.pelicanparts.com/porsche-911-technical-forum/818437-simple-question-about-gauges-need-some-beginner-advice.html
javadog 07-26-2014 02:14 PM
ONCE UPON A TIME, the handbrake light was located at the top of that gauge. In 1976, they moved it to the dash, with the seat belt light.
So, from 1976 on, there is an extra, unused light.
JR
Discseven 07-26-2014 02:27 PM
Thanks Porwolf for looking up the wires and the link. I'm going to check my wiring against your color codes. Given what you, Pat, and others have said, I'll let sleeping dogs lie in regards to the plugged top indicator in the temp / oil press guage. Am still looking to sort out the green wire --- first a check of the existing connections per your codes. I appreciate the note on the ground symbol too --- thanks!
porwolf 07-26-2014 04:11 PM
Discseven, thanks for bringing up the issue of the mystery 3rd indicator light on the oil gauge. Now I am thinking of hooking it up as an indicator light for either the fuel pump and/or the air flow switch.
Discseven 07-27-2014 04:17 AM
Interesting idea Porwolf --- we might as well use that slot for something. Please elaborate on your thinking... as in what the light would indicate? Low pressure? Broken circut? And what "air flow switch" are you referring to?
Discseven 07-27-2014 04:31 AM
JR
Very definitive note JR --- thank you.
spuggy 07-27-2014 06:28 AM
JR
Seem to recall the Owners Manual for my '77 says it's for the Sportomatic over-temperature warning light (sporto's shared the engine oil), where fitted.
E Sully 07-27-2014 06:57 AM
It would definitely seem a previous owner had hooked that wire up incorrectly.
Do you have the owners manuel for your car? I would think it would explain what the gage indicator lamps are for in the instruments.
I don't have a diagram for your car, but the only green wires used that I know of are for the fuel sender, wiper motor, sportmatic oil temperature, electronic speedometer, and a/c.
Discseven 07-27-2014 01:26 PM
I do have the manual Ed... good idea to look at it! I haven't looked at it for years --- our forum being the defacto place to go :) You guys are GREAT!
targa80 07-27-2014 08:30 PM
These two pics are from the part 2 of the 1973 schematic with my note on the green wire that goes to the large combination gauge (Temp /Oil Pressure). You can save these pics to your computer and enlarge them for clarity in a viewer program. The schematic and legend is on the host web site.
http://forums.pelicanparts.com/uploa...1406516647.jpg
http://forums.pelicanparts.com/uploa...1406516681.jpg
Attached are the photos of my 80SC gauges prior to dismantling the car in 2002 for a restoration.
This pic is of the Large combination gauge (Oil Temp/Pressure gauge) in question and you can clearly see the open light socket and the green wire is in the lower left side of the pic and the female terminal is not connected to anything, it just lays in the back of the harness. There is a green wire that is connected to the small combination gage (Fuel/Oil Level Indicators) This green wire is for the fuel indicator from the fuel sending unit. As I stated earlier in this thread, "I was unable to find any schematic showing this unconnected green wire is used on the 80SC".
http://forums.pelicanparts.com/uploa...1406514710.jpg
This pic is the Clock and the Odometer wiring for reference.
http://forums.pelicanparts.com/uploa...1406514775.jpg
This is the Tachometer wiring for reference.
http://forums.pelicanparts.com/uploa...1406514890.jpg
Discseven 07-28-2014 01:19 AM
Great diagram and pics Pat. Focusing on the green wire in the diagram, it appears that wire does terminate (small orange arrow below) off the guage as I read it. (Thanks for posting other guage pics. I was wondering about back of tach related to another project I'm working on: http://forums.pelicanparts.com/porsche-911-technical-forum/822082-clearing-fuel-guage-fog-without-removing-glass.html ...actually it was that project that led to this thread.)
http://forums.pelicanparts.com/uploa...1406532616.jpg
And the photo (taken in 2002!) with your '80 green wire coming out of the temp / oil pressure cable and it not being connected (I see it)... and your empty "post #6" (according to Porwolf's reference)... we're at the holy grail here. Great stuff! I suggest this being good confirmation between our '80's (and for similar years) that the "hanging green wire" coming from the temp / oil pressure harness is mute. More, your top indicator light is --- like mine --- vacant. Porwolf's suggestion to use that vacant space is an excellent idea. We should think about that.
Guys... read the "CAUTION" note in the diagram's legend that Pat posted (just above this post.)
targa80 07-28-2014 07:17 AM
my vacant red light is now used for the factory alarrm armed flashing indicator. during the day the flashing light is just visible but at night it would be very noticable when the alarm is active.
E Sully 07-28-2014 08:56 AM
Has anyone had a chance to check the owners manuel to see if there is a purpose shown for this indicator lamp?
Back to the Green wire.
"Focusing on the green wire in the diagram, it appears that wire does terminate (small orange arrow below) off the guage as I read it. "
In regard to the 73 diagram, here is a diagram I put together earlier in the week for the Early S Forum regarding that wire. It is in the earlier cars for the Sportmatic oil temp, and is shown unterminated by the gage. The other end at the 14 pin engine connector also has no connection except on Sportmatic engine wire harnesses.
I am wondering regarding your Green being melted. I have checked the wire in my 1973.5 harness, and it has no connection at the 14 pin connector. It would not melt from a short if it was incorrectly put on one of the terminals at the gage, since the other end sits unterminated at the engine 14 connector. It makes me wonder if it is the same Green for Sportmatics, how yours melted from a short.
http://forums.pelicanparts.com/uploa...1406561400.jpg
javadog 07-28-2014 09:23 AM
At the risk of repeating myself...
"ONCE UPON A TIME, the handbrake light was located at the top of that gauge. In 1976, they moved it to the dash, with the seat belt light.
So, from 1976 on, there is an extra, unused light."
Discseven 07-28-2014 12:26 PM
ED, I have my manual but it's archived for collectors sake so not within easy reach. I plan to get it this coming weekend and will see what it says and post comment.
I've had this '80 since '92. Have poked around doing various things under the dash but have never noticed the wrapped wire until a few days ago when dealing specifically with these guages. There's no telling what the PO did --- he could have connected the other end somewhere and this end who knows where. Your note on the other end makes me curious now --- where is the engine 14 connector? I'll take a photo of it and post for our edification.
LMFAO Java!
javadog 07-28-2014 12:29 PM
And for those of you that have a later production SC and don't have the extra indicator light, well, it eventually went away. And, let's not include the few sportomatics out there... They had extra special (extra) lights.
JR
E Sully 07-28-2014 01:13 PM
JR,
I'm not questioning you, I was just curious what was shown in the manual. I know the handbrake indicator was moved in'76.
spuggy 07-30-2014 02:42 PM
JR
The '77 didn't have extra lights for the sporto, it had one according to the owner's manual, which gives "Sportomatic oil temperature warning - (if fitted)" for the otherwise-unused indicator light at the top of the gauge with no icon. Which is pretty much the same gauge as the early SC's (which started the next year) got.
What did they do for the sporto warning on the pre-76 cars, where that top light was for the handbrake like the photo Porwolf posted? Personally, I thought all the 74-77 gauges were very similar (modulo the temp gauge sender/scale differences on the '77), and E. Sully has posted a 73.5 wiring diagram showing the top light used for "sporto temperature warning" - so do you know what year(s) had the handbrake warning there?
I personally could never figure out why they didn't use that empty light in the gauge for the CIS/OXS service interval warning light instead of drilling a hole in the dash...
theiceman 07-30-2014 02:59 PM
My 78 has that spot too . i was considering building small comparator circuit and have a light come on if my alternator hits a high and starts overcharging .. then i will still have to stock look without a voltmeter and i am protected.
i was thinking say 16.5 volts and BAM light is on. i could use a comparator and a one shot.
spuggy 07-30-2014 03:36 PM
Originally Posted by E Sully (Post 8186583)
JR,
Here for posterity are the sections from my 1977 911S/Turbo Owners Manual.
Note the manual transmission 0-340 F temperature gauge, which works with a '77, 3.2 or any 930 (turbo) sender; the '74-'76 with manual trans had a 0-300F gauge - and those require a different sender - same one as (at least) the '74-'76, maybe some earlier - & the SC:
http://forums.pelicanparts.com/uploa...1406759263.jpg
http://forums.pelicanparts.com/uploa...1406759284.jpg
http://forums.pelicanparts.com/uploa...1406759302.jpg
http://forums.pelicanparts.com/uploa...1406759322.jpg
E Sully 07-30-2014 07:23 PM
Thanks spuggy
d.a.autry 09-10-2017 04:27 PM
Glad I found this thread. It answered my questions about the top (empty) indicator lamp on my '76 (Thank you Javadog for your response, my '76 manual doesn't mention its use in the verbiage, however the picture of the gauge does still show the brake symbol below it)
AND
It answered my question about the unconnected darker solid green wire (Thank you E Sully and Discseven!).
NOW, can anyone comment on why in the hell they would use a GREEN indicator (Universal for 'go' or 'good') as an idiot light for low pressure???
Simonrex55 10-13-2021 10:31 AM
So i have this gauge, and the back is also vacant. My engine/gear box and wire harness came out of a 1976 911s.
Actually, it has 2 male spades, but I’m not sure what to plug there either. What’s the “idiot” light? My engine is a. 2.7 CIS.
timmy2 10-13-2021 01:13 PM
Green wire is for Sporto oil temp, and so is the lamp hole.
