-   -   Unusual engine code (http://forums.pelicanparts.com/porsche-911-technical-forum/822342-unusual-engine-code.html)
PDX-944 07-25-2014 09:58 AM
Unusual engine code
So here's my current mystery. I bought a 77 targa converted to slant nose yesterday, and I can't seem to figure out what engine I have. Should have been a 2.7 according to vin 9117210595
However the numbers by the fan are *3280888* and 930/06
930/06 indicates 3 liter
*3280888* I find one reference to, here: Porsche Engine Numbers
But that points to a really early motor and doesn't match the 930/06
Here are pictures
http://img.photobucket.com/albums/v3...pso19d5qd9.jpg
http://img.photobucket.com/albums/v3...pspa8z7oe3.jpg
http://img.photobucket.com/albums/v3...ps0ekf6uof.jpg
gerben1986 07-25-2014 10:00 AM
Is it 930/06 or 930/08?
In the /08-case: 3.0-liter 911 SC engine for Japan
PDX-944 07-25-2014 10:25 AM
Its definitely 06. Maybe not clear in the pics but it's a 6.
HelmetHead 07-25-2014 10:28 AM
RedBook says its from a 68 911 coupe #3280001-3281606 (901/14) which is probably what you have already found. Could it be a replacement case restamped to earlier number?
PDX-944 07-25-2014 10:32 AM
I have no idea what it could be Haha. I'll tell you (although I come from 2 944s), it's got a lot of pep.
PDX-944 07-25-2014 02:35 PM
Post number 6 here is my situation: http://forums.pelicanparts.com/porsche-911-technical-forum/758780-engine-number-question-74-911s-targa.html
The case may be from 68, but if that's the case then it was restamped 930/06? Making it...? Unknown without a teardown?
PDX-944 07-25-2014 07:50 PM
Ah hah! Notice under the slash in 930/06, there's a 9 ground off.
New theory is a service part restamped
PDX-944 07-27-2014 10:36 PM
Pulled the motor out for valve adjust.
It has 4 journal cams which I'm told makes it 3.0
2.7 distributor and cdi box. I'm still in the process of learning about 911 motors, and this one's thrown me for a loop!
E Sully 07-31-2014 08:28 AM
The 930 101 103 4R casting number would be SC. Serial number makes no sense. Case would not be a Porsche restamped '68.
Tom Butler gives a nice overview of engine cases.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/351932-r-case-designations.html
The cap'n 07-31-2014 09:46 AM
It's clearly NOT an early chill cast case because the longitudinal fins are missing, among other details. The casting number is wrong, too. It has a 2.7 exhaust system (one of the worst available) I suspect the numbers have been altered, or possibly it was an unnumbered case that had numbers stamped to suit the needs of the person who installed it. I think the 930/06 is authentic, I doubt the actual serial number is. Per the specs book, all 6 cylinder engine serial numbers of that era should have as the first digit a "6". This is clearly a "3". The second digit is a "2", indicating a ROW engine, the third an "8", indicating a 1978 model year. The last 4 digits indicate the "0888th" engine in the series.
The Cap'n
Matt Monson 07-31-2014 10:03 AM
Made on a Friday after lunch. Too much beer in the stomach of the tech who stamped it.
PDX-944 07-31-2014 10:46 AM
Finally some answers!
Those dang Germans
PDX-944 07-31-2014 10:49 AM
The Cap'n
What you might have missed is that right under the slash in 930/06 is a partially removed 9, leading me to believe THAT was the restamped number. But I could be wrong
E Sully 07-31-2014 11:19 AM
The 930 101 103 4R is part of the engine case original casting, but all other stamped numbers are suspect.
Any chance it was a '77 3.0 Carrera case?
techman1 07-31-2014 12:03 PM
I seem to have a faint memory of engine serial numbers preceded by a star indicate blank case stamped as replacement engine?
