Euromeister Brake Clearance
Hello,
I'm wondering if anyone has successfully fit a Euromeister 17x7 on a Carrera 3.2 with Boxster brake upgrade? I am aware that the Euromeister front offset is the same as OE Fuchs (23.3) but that does not tell the entire story. Does anyone have a caliper clearance template? Thank you in advance, Rob |
If in the case no one has fitted a euromeister wheel with boxster brake upgrade, can anyone provide the minimum distance between the wheel to disk. This will give me some reference.
I've had a few emails with Pelican, however, the representative wasnt able to help with a brake clearance template. A little disappointed on that one.
Anyone with a 17x7 Euromeister, if I supplied you a template via printable pdf (positive shape of the brake rotor/calliper) would you mind checking the clearance?? Alternatively, anyone in Melbourne Australia, would you be able to help out with a trial fitment? Thanks all. |
i think i can help. if you provide the template, i just have to print it out, pull the wheel and put the cutout against the hub?
Hi froggert,
You've got it. The template I provide you will place against the wheel, it will represent the the brake calliper position. If there is clearance a few millimetres then it should be acceptable. My car is in the shop for most of next week, once back I'll contact you with the template. Thanks again, Rob |
sounds good. let me know when you are ready.
Closing the loop on this issue, thanks to froggert I can confirm that a Euromeister 17x7 will clear a Carrera front with upgraded Boxster brake callipers, well at least the template.
If anyone would like a copy of the template please PM me and I will send you a PDF. Images below: ![]() ![]() ![]() Rob Last edited by robcf; 08-06-2014 at 01:31 AM.. |
