-   -   '87 3.2 G50 - rough idle/stumble when accelerating (http://forums.pelicanparts.com/porsche-911-technical-forum/823173-87-3-2-g50-rough-idle-stumble-when-accelerating.html)
alfisti 07-30-2014 12:47 PM
My car seemed to just develop this problem that I THINK has gotten progressively worse. Symptoms as follows:
* Rough idle, either hot or cold. It's idling very low, like 600 RPM, a lot of hunting - nearly stalls (has stalled a couple of times but it's rare) and occasional popping
* On acceleration, there is a hesitation or stumble. It's like how it feels when the engine is lugging at low RPM. It seems that I get through a particular stumble and the engine is OK again... it's hard for me to tell if it's making full power, but at least some of the time, it pulls like a freight train
Some things that have recently been done:
* New cap and rotor. Smoothed out the engine a lot but didn't solve the problem
* New air filter
* 3 tankfulls of gas with a bottle of Techron in each
* Took apart AFM and bent the wiper arm to ride in a new arc. Old one had a couple of bare spots, but I've seen worse in other threads on this forum
I have a new O2 sensor on order, should arrive today. I'll install that and see if it helps at all.
But I'm looking for other ideas. Any ideas on where else I should start?
-Glenn
alfisti 07-30-2014 12:58 PM
Just another observation.. the stumble happens at full throttle, too - althought it seems, less frequently. Doesn't that mean it can't be the O2 sensor?
-Glenn
p.s. the car has 234,000 miles on it, 10,000 of which were done by me over the last 7 months, in sheer bliss
tsiegwart 07-30-2014 01:01 PM
If you unplug the O2 sensor and it smooths out, you will know it's the O2 sensor. It switches to a different mode of control in the ECU. If you unplug it and it doesn't smooth out, it's something else.
Another suggestion is new wires. Also temp sensor. I don't know of any tricks to test that.
alfisti 07-30-2014 01:02 PM
Ok. That's an easy enough thing to test, thanks.
tsiegwart 07-30-2014 01:02 PM
Ah!! Full throttle stumbling would indicate it's not the O2 sensor. The "wide open" sensor takes the O2 sensor out of the mapping equation.
JeremyD 07-30-2014 02:35 PM
I had this issue on my old 3.2 - I changed the coil and the plug wires and it went away. Definitely seemed to be ignition related,.
Scooter 07-30-2014 02:48 PM
+1 on the O2 advice above. I would also change plugs (wires and/or coil?) to go with that new cap and rotor.
alfisti 07-30-2014 03:23 PM
Another possible clue: There is no fast idle. The pattern of it starting around 1000-1100 rpm and then selling down to 800 isn't happening anymore. Does that mean anything?
alfisti 07-30-2014 07:06 PM
Found the problem! One of the plug wires wasn't fully seated. What boneheaded did that?!?! Oh wait a minute... That was me :-/
Well I just fixed it and took it for a drive, and OMG, what a car. The sound of the engine echoes in my head even after shutting it off... Wow.
Thanks all!!!
alfisti 07-31-2014 06:40 AM
Just not nearly as badly as before. Is it possible the plug has been fouled?
alfisti 07-31-2014 06:55 AM
Not sure what happened with that last post... What I meant to say is that, while it is MUCH better, still a mild stumble happening. Is it possible the plug is fouled?
Sent from my RM-877_nam_att_205 using Tapatalk
Scooter 07-31-2014 07:54 AM
I would just change the plugs. Cheap and easy...and just good maintenance.
TheSt|G 07-31-2014 08:35 AM
Change the plugs. Costs what, $20? Check to make sure you have the wonderful Porsche specialty tool first.
alfisti 07-31-2014 08:53 AM
is this the tool? 1987 Porsche 911 Carrera Coupe - Ignition - Page 2
alfisti 07-31-2014 08:56 AM
sorry, bad link. Is this it? Pelican Parts - Product Information: TOL-SK4490
997Sbeebe 07-31-2014 09:54 AM
they're probably referring to this tool - in your tool kit.
http://forums.pelicanparts.com/uploa...1406825638.jpg
alfisti 07-31-2014 10:14 AM
Oh. I do have that. Wondered what that was...
VMAX1 07-31-2014 11:06 AM
You probably need to check for vacuum leaks, while your back there. A ton of threads on that. If you haven't got the Bentley, you might want to invest in one.
DRACO A5OG 07-31-2014 11:46 AM
You probably did this, but did you replace the Fuel Filter?
