Proper Top End Rebuild
What does this consist of?
valve job
valve guides rockers rebushed rockers resurfaced cam polish piston and cylinders if alusil. (some have reused alusil pc's) piston rings P and C's if out of spec check wrist pin bushings if CIS: replace injector sleeves Orings rubber sleeves on intake runners vacuum lines injectors cleaned and checked optional: clutch at least a disk and TO bearing pilot bearing this is assuming no broken or pulled head studs. |
Perfect answer thank you. I'm a newb...is the valve job and valve guide and rocker work all done as apart of getting the heads rebuilt by Anchor Atlantic? Or are these separate tasks?
sepertate. you will have to ask for them to be done.
the big issue is piston and cylinders |
I would suggest talking to Mark at Exotech (603-382-3599 or prschmn@comcast.net) for having the heads done. He does a ton of them and you'll find lots of happy customers around.
I recently had my heads and rockers done by Craig Garret (Pelican username cgarr).
He did great work, the turnaround was pretty quick, he communicated well, and his prices were very reasonable. As far as Porsche machine work is concerned, I haven't seen those four qualities together anywhere else. |
Ok so these shops can do the valve job, valve guides, and rocker work when I send them my heads? Or do I send the valve stuff out to another shop? Sorry for my probably silly questions...it's just that the words valve job have almost no meaning to me so I'm not really sure if that is a task that Craig Garret, exotech, and anchor Atlantic do while they have the heads or if I send elsewhere as separate project.
+1 for Craig. He did my heads and rockers a few years ago. IIRC, he is not set up to regrind the cam.
Rockers and cams can go separate ways, depends on who you use. Here is my thread from four years ago. |
I'm guessing they could all take care of your cams, but most people (as in if they are not a cam shop) send them out to be reground. You could do that yourself or have the person doing your head take care of it. |
garrett - you have one of the best shops in the Southeast right around the corner Porsche Racing Goldcrest Motorsports: Racing
They love air cooled 911's |
I literally just picked my car up Tuesday from them after having the top end rebuilt. Excellent work and extremely happy so far (except that my car is stuck in my garage with some bugs unrelated to what they did). |
you may want to inspect the cam sprockets, chains, ramps. I shimmed the idler arm to limit travel. You can also consider installing tensioner limit devices. I used the spacer inside the barrel method.
| All times are GMT -8. The time now is 08:46 AM. |
