-   -   Better idle...what happened? (http://forums.pelicanparts.com/porsche-911-technical-forum/82381-better-idle-what-happened.html)
bigchillcar 09-29-2002 10:54 PM
It's been months since I've posted. Good to be back at the board. Thought I'd solicit opinions on my car's idle (stock '74 911 CIS). I always start per the manual - hand throttle up until warm and then whatever is necessary to maintain just under 1000 rpm's. This has worked fine for me since I bought the well-maintained car back in December of last year, but for the past couple of months, it hasn't idled very well unless i keep the hand throttle almost all of the way up all of the time...put it down and it would likely stall.
Had a theory that all it needed was to be run hard and burn carbon off of the plugs, so I took it on two three hour trips (driving particularly fast) and replaced the battery. Now the car idles just fine - hand throttle up to start for a few minutes then all the way down and it idles great...maybe a little high (1100-1200). This sounds dumb...did my car fix it's own idle just by giving it a good hard driving?
:cool:
47silver 12-08-2002 06:32 PM
idle
hi
mine is doing the same thing, i will have to try out your theory
gar
pwd72s 12-08-2002 07:52 PM
Any change in fuel sources?
bigchillcar 12-08-2002 08:39 PM
Since I posted this in September, my knowledge of CIS, etc. has jumped by leaps and bounds. Almost funny to see my old post now that I'm such a 'pro'!;)
I've since learned how to replace points, use a dwell meter, check and set timing, adjust idle air bypass, etc. and no more of this problem. It seems the more I work on this car, the more I want to work on this car...and so on...:cool:
Ryan
Rot 911 12-09-2002 07:34 AM
Just be happy.:D
