steeting wheel swap and turn signal return thingy
Hello,
Gonna swap my steering. Wheel. Do the Momo's come with the return thingy or should I save the one from the stock wheel? Car is an SC Thanks |
"O"man(are we in trouble)
You will need to switch it from the old hub, two screws if I recall correctly.
3 screws and the cancel tab sits at 9 o'clock.
2007 Cayman 1986 Carrera coupe (sold) 1979 911 SC targa (sold) |
I found I had to add a washer under each mounting hole too space the cancellation ring forward. Without it, my left signal would not cancel.
Good luck, Dave |
