Heck, I’m only 5 not 71!
targa80's Avatar
Window glass adjustment on a Targa
I know how to adjust the glass as far as how high or how low it goes. The problem I am having is with the passenger side glass not completely sitting into the top rubber trim. It seems the back of the glass sits further away from the top rubber trim than the front of the glass does. I have had the entire frame out for a repaint this past week. The drivers side glass is sitting perfect after I installed the trim and made height adjustments. The passenger side is not seating properly and there is some binding when the glass is just past 3/4 of way down. In other words it binds slightly then continues the rest of the way down. I know this is not correct and it has to do with the frame rails not being aligned correctly. I believe I can figure out the binding issue. What I am looking for is any suggestions from the experts on how to fix the glass to seat properly in the rubber top seal? This issue occurs when either I close the door or lower and raise the window.
Passenger side
Driver side
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 09-24-2014, 07:56 PM
Cooper911SC's Avatar
As you know the glass is adjustable for height.
It is also adjustable for squareness in relation to the window "frame" channels.
You need to loosen the two bolts that allow you to "cock" the frame into the most square fit.
Sorry, surfing from phone so can't post links...
The bolts are located toward the rear of the door in relation to where the slot for height adjustment is.
Cooper
Old 09-24-2014, 08:18 PM
boss11's Avatar
I have a similar issue on passenger side door as well, would like to see more before I pull the door appart
82 SC Targa Guards Red = Toy
04 E55 AMG Brilliant Silver = DD
04 Cayenne Turbo Platinum Grey on 22s = Previous DD
80 Wide body 12AT RX7 Black 350+ hp= Previous Toy
78 Alfa Romeo GTV Blue = My 1st Cool Car
Old 09-25-2014, 01:11 PM
targa80's Avatar
Bump!
Pat Henry
Targa80
Old 09-26-2014, 04:28 AM
theiceman's Avatar
also the side trim on the targa roof is adjustable .. there are 4 or 5 phillips screws that allow the rubber piece to be alligned with the window.
The problem i see is with so many adjustment points available where does one start ... ie what becomes the reference.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-26-2014, 05:19 AM
Type911's Avatar
Pat,
Sent you an email on this.
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 09-26-2014, 07:44 AM
