-   -   Trans and Motor Mounts- Type/Difficult? newbie (http://forums.pelicanparts.com/porsche-911-technical-forum/824064-trans-motor-mounts-type-difficult-newbie.html)
Mean951 08-07-2014 07:24 AM
Gentlemen, Thank you.
Anthony
wolds 08-07-2014 12:57 PM
You might want to remove, clean and reinstall your main ground strap while you're under the car. If you have a new one handy, better yet. Warren
Draden 08-07-2014 01:49 PM
Good point Warren. Such a small item and easy to forget, but a bad ground forces all your starter current to return path to the battery via the clutch cable. The result is it becomes brittle and breaks easy. Not to mention a weak ignition spark. -Draden
Mean951 08-07-2014 02:56 PM
I will change it.
Thank you!
