911 calliper adapter
Hi , have a question , after checking out as many post`s on Boxster calliper upgrades as I can find ,I`m unable to find my answer. I have Boxster non S front (1997 -2005) callipers to fit to my 3.5 inch spacer Bilstein struts, I have existing aluminium S calliper`s on standard 282mm x 20 mm rotors, the issue is, I have 17 inch front rims and have bought 298 mm x 24 mm Boxster rotors instead of 282mm x 24mm mid eighty`s Carrera rotors that should be used if wanting to use original smaller rims, what calliper adapter do you use now if the new rotors are 16mm larger in diameter? Do I purchase the calliper adapter kit that fit the smaller Carrera rotor`s and make some kind of spacer to lift calliper higher ,have special adapters made up or is there a kit that fits these callipers to original 298mm rotors. Hope this makes sense. Many thanks for any help on this subject. Cheers Brett
