Car Not Run Often
My 77 has not been used much over the past few years. Wondering what would be the best way to freshen up the fuel system? Cleaners, higher octane fuel? Anyone have any tricks or products that have worked well?
Looking forward to exercising the old girl Thanks, Tom |
Straight shooter
Did you use fuel stabilizer and how much fuel did you leave in it last?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Non Compos Mentis
If my car is going to sit for a while, I put 100LL Avgas in it. No alcohol, stays stable for long periods.
Car never failed to start after sitting a few months. |
BG44k
Techron Liqui Moly fuel system cleaner
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
Car has OK fuel. Runs decent but want to put something in that will give her a cleansing throughout the systems.
Straight shooter
Oh then just fill it with the good stuff and drive it. Best medicine is use!
Vintage Owner
Fuel system cleanse
Though I've long used Techron, SeaFoam, and other cleaners over the years, I think that driving the car regularly is best. Actually, ethanol laced fuel may also help as the ethanol dissolves some deposits in the system. Just don't leave it sitting for long periods of time in the tank, giving the fuel a chance to phase separate and eventually turn to jelly.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Thanks guys. I'm going to put some good fuel in her, maybe a bit of cleaner and hit the road. Great forum- good people
