Windshield wiper motor drive arm stripped
I have a 70 Targa and the windshield wiper motor drive arm is stripped of the knurling. The knurling is good on the motor. My only thought is to drill the arm and put in a set screw which would be a pain to do. I am supprised not to find this problem addressed on the forum as I bought a 74 setup complete {used} and it has the same problem.
70 911 targa 47 dodge pickup street rod restored 54 chev flat bed dump 39 chev suburban project 2000 bmw 528i |
RETIRED
Buy a new arm.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
They wear out especially if the owner has tried to clear heavy snow or ice from the windshield. The motor is very powerful and it will not stall but it will strip the splines (knurling) from the arm.
Buying a used one is a crap shoot. I would call Parts Heaven in Oakland, CA and ask if they have one that is like new, and if not I would order a new one from a dealer. Call mine, Isringhausen in Springfield, IL. Their parts guy is great!
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries! 1974 911 RUF Clone ('85 3.2; '86 915) 1974 914 ('87 3.2L & 915 transaxle) 2005 Boxster (Base car) Guards Red. |
Brew Master
I have one from my 75 donor I was keeping for a spare just in case but if you need it, let me know what it's worth to you and I'd probably sell it. I honestly only wanted the motor off of it since I figured that would go bad first. Maybe not huh?
I was so hoping for an easy fix but such is life, eh?
Cabmando, I want to check locally first and make sure the 70 and 74 interchange but I will get back to you in a couple of days.Thanks. The wipers were iced to windshield, not obviously, and a couple of seconds and later gone working wipers.
Yes, it only takes on half second for the motor to turn when the arm is stuck to strip out those splines, most especially if the nut holding the motor shaft to the arm is a little too loose. I think all wiper mechanisms from 69 through 89 are interchangeable. (and maybe from 65 through 89).
And I still think the best source is Parts Heaven in Oakland.
| Tags |
| stripped knurl , wiper motor drive |
