Doug Zeilke, shim for CIS enrichment
Doug,
In reply to my post with questions of CIS, I told you wrong about the pressure regulator shims. I think I said "fuel inlet" to the mixture control. I just checked. On 924t, it is under a hex head screw, that is at a right to a big banjo fitting for fuel return & a small one to warm up regulator. More shim should increase the system presure & make mixture richer for flap movement. Sorry, hope I caused no inconveinence. drew1 |
| All times are GMT -8. The time now is 11:23 AM. |
