Help: Attaching Turbo tail
I know this is hardly a difficult subject, but mounting a 930 tail to engine lid.
What is proper bolt/nut or screw/nut combo ( i.e. size/ length) to make it as it should be as opposed to certifying me as hack.
Terry
TOT
Old 11-02-2014, 11:55 AM
Cars and Cappuccino
tdw28210's Avatar
The threaded bolts should be protruding form the rubber. I think they are 10mm coarse threads. So get 16 or so 10mm nuts and washers. If the bolts aren't there, then you need a new rubber tail.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 11-02-2014, 03:31 PM
turbo tail
Sorry that is not what I meant.
The whole tail attaches to the engine lid....there are holes in both to attach.
I would like to know the proper bolt or screw specification that should be use to be correct. I could "make it work" but would rather do it correctly.
TOT
Old 11-02-2014, 04:50 PM
I've asked that before and didn't get much info. Ended up going to Lowes and getting stainless steel 10mm hardware.
Old 11-02-2014, 05:14 PM
wrxnofx's Avatar
I'd suggest downloading the PET for your specific year.
Here is what it shows for the tail:
I don't have a tail so I'm not that familiar, but it looks like you need 3 M6x10 pan head screws (#7 in the pic), 5 spring washers (#8 in the pic), 5 M6 captive nuts (#9 in the pic), 7 M6x15 pan head screws (#10 in the pic), and 10 M6 washers (#11 in the pic).
Looking at part number N-0122-265-OEM (the spring washer), it appears to be CAD plated, so I'd not be surprised if the other fasteners were, too.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 11-02-2014, 06:23 PM
frankc's Avatar
In addition to the fasteners, you will need the "base rail" piece (#12/13) that fits on the under-side of the lid and helps to evenly displace the clamping force of the fasteners. Let me know if you need a photo and I'll post my lid+tail. It is a Carrera tail, but same pieces.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-02-2014, 07:07 PM
Tail
thanks guys
Wouldn't mind pic you referred to ...Trying to figure what I am missing
Big help though
TOT
TOT
Old 11-04-2014, 05:16 PM
