I still have a clicking sound coming from my engine when I start it and it stays till it is warmed up. I have searched the valves with a long screwdriver and they seem good. I think it is coming from my pressure fed tensioners that I installed last winter.
The sound does go away when the engine is warm. And it has done it all season ( approx 2500kms) But what else could it be? My thoughts are chains or chain rails?? Am I just being overly nervous, I've heard that the pressure fed tensioners make noise but this is a loud ticking till its warm. Shawn |
Senior Member
Sounds like a valve out of adjustment. Ticking.
Chain problems would sound more like rattling or rumbling or whining. ------------------ '83 SC |
Senior Member
Hey, I had the exact same symptoms a year ago before I rebuilt my motor.
I had the tensioner upgrade as well. And it went away after the motor warmed up. I removed the chain covers and looked for broken rails or evidence that a worn chain was making contact with the housing. I couldn't find the problem. And it persisted. Now that i have my engine running again I can say, although it leaks (dammit) it dosen't make that noise anymore. maybe it was the chain...I dunno. |
Check for leaking header gaskets. They can sound like ticking and go away when warmed up. Alex
Thanks all
Alex, that sounds like it could be it. Leland sorry to hear about the leaks. I pulled my engine last winter to fix some leaks and install the tensioners and it leaks worst than ever? SO I pulled it last week replaced some seals, its better but still bad. I still haven't replaced the seal between the engine and transmission, will do that and more next month. Good LUck and thanks |
Senior Member
I think that Alex is right. Anyone who has owned an 80s or 90s Subaru or 4-cylinder VW knows that the manifolds love to warp. When they do, you first get a distinct click that goes away when the heat closes up the leak via expansion. It sounds EXACTLY like a bad valve/lifter and will throw you for a loop.
Jw |
