mordecaibrown's Avatar
1977 Porsche AC compressor
I have a 1977 Porsche 911s AC Car and the original owner removed the AC compressor. Will this compressor work form my car. i see a 10-77 on the tag. is that the date?
Also will I be better off going with a Saden unit or a Denso?
Thanks,
Sam
Old 08-29-2014, 04:24 PM
Fleabit peanut monkey
Bob Kontak's Avatar
It's for the 1978 model year if 10/77 is the date. I do not know if it will retro fit.
Yes on the Denso or Sanden.
1981 911SC Targa
Old 08-29-2014, 06:52 PM
Thanks Bob for your rely! Also with this Sedan unit work?
Sam
Old 08-29-2014, 07:12 PM
Bob Kontak's Avatar
Hi Sam,
Pretty sure that will work. I have a 507 on my 81. It has a double pulley.
You will need a mounting plate that sits on top of the old York steel plate and some bolts and nuts to secure the unit down.
You can also search for a used mounting bracket if you are on a budget. Charlie Griffith will sell you the mounting bracket and hardware kit. Griffithstech.com. Pelican carries his products as well.
I found the compressor on Ebay you posted. The seller has a 100% rating and it's re-manufactured.
However, your system is "open" which requires a receiver/drier change out.
1981 911SC Targa
Old 08-29-2014, 08:22 PM
Thanks again Bob, Where can I get the Drier? Also how about the hoses?
Sam
Old 08-30-2014, 06:25 AM
