nostatic's Avatar
rattle at 6K
While blowing some carbon out of the car today, as I climbed to 6K I heard a rattle from the rear of the car. I backed off and it immediately went away. I didn't get up to 6K again on the drive, but nothing at 5K. It sounded like a sheet metal rattle (but I couldn't exactly get out and look at that point in time). Any ideas? I have the original tensioners if that makes a difference.
Old 10-01-2002, 03:27 PM
Bill Douglas's Avatar
Todd, that's the famous SC Death Rattle! I would be concerned.
But in the real world I would have someone else drive the car while you crawl around in the back and try to identify the sound. Do it first underload, then if you are brave enough, try it while you are parked with the engine lid up. Maybe wiggle everything first before any tests
Old 10-01-2002, 03:44 PM
makaio's Avatar
Dr static,
I don't think it would be tensioners if it stopped once you backed off.
My car made a similar sound when my first GHL muffler split at the seam. Right between 3000-3400 rpms. Bellow or above that, no rattle sound.
Old 10-01-2002, 03:47 PM
Senior Member
Superman's Avatar
Relax.
Mocha 1978 911SC. "Coco"
Old 10-01-2002, 03:53 PM
R22tech's Avatar
Heat shield for Cat. conv.? description sounds like an exhaust rattle, so check all muffler straps, clamps, bolts, ect.
85 Carrera Targa (sold!)
03 Dodge Ram 1500 HEMI
Old 10-01-2002, 03:57 PM
nostatic's Avatar
Originally posted by Superman
Relax.
That's what the Xanax is for. I'm not that worried since at 5500rpm is sings right along (and what a song). It sounded exhaust related, but I was just curious.
Thanks Bill, I think i just forgot to turn the light sabre off
Old 10-01-2002, 04:03 PM
R22tech's Avatar
I'm not sure if yours is like mine, but check here:
sometimes LOOSENING the bolts that hold this shield on just a touch does the trick!
Old 10-01-2002, 04:17 PM
Todd,
Do you think it might be detonation? Check ignition timing. Check for any loose sheet metal, then try it again. Try it with a load of 93 and/or race gas and see if it makes a difference. We don't want too many SCWDP cars falling by the wayside. :-)
Sherwood
http://members.rennlist.org/911pcars
Old 10-01-2002, 04:25 PM
Early_S_Man's Avatar
Porsche Crest
Sounds like something exhaust or sheet metal related -- not tensioners!
Don't worry -- the tensioners will let you know, each and every time you start the engine up cold -- when their time has come ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-01-2002, 04:32 PM
nostatic's Avatar
I don't see that on mine...only a smaller shield:
nothing on this side
I do have one of these though:
and one of these:
Old 10-01-2002, 04:38 PM
Information Junky
island911's Avatar
At 6k (and only around 6k) it's not likely detonation. The pistons start lossing their ability to pull a full charge of air around 4k.
My guess too, would be sheetmetal rattling.
. . or your SC is simpley saying; 'Todd, I need some SSI's
Old 10-01-2002, 04:47 PM
nostatic's Avatar
"yeah honey, I gotta fix that noise. A set of SSIs and a Dansk should do it...less oxidation down there too."
Let's see...how much did she spend on Japanese wood block prints in the last month?
Old 10-01-2002, 04:49 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Dr. Static, I have found your problem!!
You have no signs of oil, grease, or sluge under your car. You should really know better, know wonder everything under there is rattling around. Nothing to keep it together!
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 10-01-2002, 04:50 PM
Almost forgot, the pots & pans arived today. I'm waiting for her to get home to open them, and cook me dinner!
'81 911SC Targa 3.6
Old 10-01-2002, 04:52 PM
nostatic's Avatar
Dr. Williams, I hope it is worthy of Iron Chef status. If not, tell her to get the money back and buy some AllClad (and save a $K or so)
Old 10-01-2002, 04:57 PM
Botman's Avatar
NS,
Perhaps you have the dreaded SCWDP "sticker shake syndrome."
Did you have this mysterious rattle BEFORE pledging your allegiance to this subversive group by applying an obviously defective decal to your vehicle?
Are you sure you're not hitting the rev limiter?
Mike Patterson
Obsessive in Texas
86 3.2 Black on Black Carrera Coupe
73 BMW 2002 Verona Red
Old 10-01-2002, 06:51 PM
Senior Member
Superman's Avatar
Lots of possible sources. Lots of sheet metal back there. Also, the guts of catalytic converters sometimes come loose and if they do, they'll rattle.
Old 10-01-2002, 07:45 PM
I detected a 'rattle' under hard acceleration a couple of weeks ago on our 'NC run'...it was very intermittent, and although I haven't fixed it yet (car's on jack stands for other reasons), I'm quite sure it's a loose muffler strap.
Old 10-02-2002, 07:14 AM
