-   -   74 911 What does this switch do? (http://forums.pelicanparts.com/porsche-911-technical-forum/82714-74-911-what-does-switch-do.html)
Porsche_monkey 10-02-2002 12:59 PM
Re-assembling my 74 911. There are two switches just above the ignition key switch. The rocker switch to the left should be the sun-roof open/close (shouldn't it?) and to the right is a small black switch which pulls straight down, what is that switch supposed to do?
:confused:
Porsche_monkey 10-03-2002 06:34 AM
Bump. Come on, somebody must know the answer to this!
bigchillcar 10-03-2002 06:42 AM
i can help with half...the first switch is definitely to open and close the sunroof. i don't have the pull-down switch you mention in my '74... for what it's worth if you haven't ever moved your sunroof before, i always 'assist' mine slightly with my hand to prevent a sticking point from stressing the plastic cables that move it along...if i've pointed out something really obvious to you, my apologies in advance!:D
ryan
Gold 1974 911 coupe w/sunroof & CIS
Porsche_monkey 10-03-2002 06:48 AM
a) Nothing is obvious to me.
b) I am not completely stupid, but the wires from the second switch run under the carpet and exit out near the torsion bar tube, where they now hang on the ground, so tracing the wires is of no help to me.
http://www.pelicanparts.com/support/...oilet_claw.gif
bigchillcar 10-03-2002 06:56 AM
hmmmm...
well is it possible that this switch was added by a previous owner? maybe it controlled fog lights or something along those lines? maybe those 'tasteful' fluorescent lights some insist on putting under their cars! Or does it appear factory?
SmileWavy
ryan
Gold 1974 911 coupe w/sunroof + CIS
Porsche_monkey 10-03-2002 07:03 AM
Switch looks a little cheesy, but it is 'hidden' under the dash, wiring is definately factory.
Maybe it's that rare 'rear fog light' option. :D
I guess I'll have to post a picture.
warment 10-03-2002 07:05 AM
I would guess the second switch is for a rear fog light...
Bill
Oldporsche 10-03-2002 07:44 AM
Hmm,
I believe that the wiring diagram shows the rear fog light would receive current when the fog light switch was pulled on. The fog light switch would be mounted to the right of the steering wheel on the dashboard with the rest of the accessories controlled by knobs. (Rear heated window, etc.)
Good luck,
David Duffield
Porsche_monkey 10-03-2002 07:57 AM
1 Attachment(s)
I should have done this first, here's a picture:
Oldporsche 10-03-2002 09:08 AM
Was you car delivered in Canada or Rest of World (ROW)? and not USA?
Makes a difference in wiring diagrams!
ICON on switch looks like rear heated window?
Good luck,
David Duffield
Porsche_monkey 10-03-2002 10:08 AM
No, that switch is in the middle of the car above the radio. this is left of the sterring wheel, pointing down, like the sunroof switch.
Roland Kunz 10-06-2002 07:27 AM
Hello
OK the switch in the facia is the rear wiper switch ( see symbol ).
The switch hanging out is a rear wiper switch too used from 68 to 73 cars. The same switch design was also used for several other tasks. Switch and wireloom look like factory.
Rear fogs had ben integratet in the Fog light switch.
Would be interessting to have a close look at the car to find out if ther switch came from the factory or was installed at a dealer and for what.
One guess is that someone installed a switch for fresh air blower in the enginebay ( wich runs on pre 75 cars all the time ) or someone installed a switch to run the coldstartvalve seperate ?
Grüsse
Porsche_monkey 10-07-2002 07:12 AM
Thanks Roland, I am looking into the coldstart idea. No rear wiper on my car, no fresh air blower. Looks like a dealer/mechanic might have installed it.
PH
Roland Kunz 10-08-2002 02:19 PM
Hello
You might not have a rear wiper now but the car maybe came from the foctory with it.
All 74on CIS have the freshairblower siting "Ford Perfectet" on the engine.
Cars built in mY 74 had that blower runing all the time with the ignition. Had been cahanged to switch on heat lever in MY75.
Grüsse
