-   -   Intake Adapters (http://forums.pelicanparts.com/porsche-911-technical-forum/827912-intake-adapters.html)
Pato911 09-01-2014 10:37 AM
Intake Adapters
I have been reading a lot on ITB's, 964 intakes and Varioram. To fit any of these requires an adapter but, so far, none of the tuners have responded to my emails. So, to keep moving forward, I spent some time this weekend drafting up some adapters using Custom Online CNC Machine Shop | Free CAD Software. I will probably have some of the GSXR and 3-bolt adapters made and, if there is any interest a few more.
My efforts so far:
GSXR750 Adapter
http://forums.pelicanparts.com/uploa...1409592591.jpg
Triumph 955 Triple Adapter
http://forums.pelicanparts.com/uploa...1409592632.jpg
3-Bolt (964/993) Adapter
http://forums.pelicanparts.com/uploa...1409592659.jpg
P
Pato911 09-01-2014 11:00 AM
Dimensions I used:
http://forums.pelicanparts.com/uploa...1409594399.jpg
merlinfe 09-01-2014 03:46 PM
Awesome. I'll subscribe to follow this. I eventually want to get rid of the CIS in my car.
Keep up the good work!
Chuck.H 09-02-2014 06:00 AM
Wow great work! What does the 3 bolt 964/993 adapt from/to?
I've always wondered if it's possible to get a 3.6 block and run the entire 3.2 DME fuel/ignition system to make an easier engine swap possible. Using either no second spark plug or a andial type splitter. I know it would leave some power on the table with the reduced intake/exhaust but not sure how much.
Chuck.H
'89 TurboLookTarga, 381k miles
prebordao 09-02-2014 07:38 AM
Great work!
Pato911 09-02-2014 07:56 AM
The 3-bolt adapter is intended to allow the use of a 964/993 manifold on an earlier car that had 2-bolt intake ports in the heads.
911pcars 09-02-2014 09:56 AM
Other than the 964/993 intake manifolds being plastic, what are the other benefits?
Sherwood
chrisbalich 09-16-2021 07:02 PM
Lazarus bump.
Did you ever make the 3-bolt to 2-bolt adapters?
Looking at putting a 964 manifold on my 3.0L engine.
Peter M 09-17-2021 03:44 AM
Like these Chris:
https://adaptmotorsport.com/products/porche-964-intake-manifold-adapter
Steam Driver 09-17-2021 05:00 AM
I have some of these already made up. Designed them for putting EFI and a 964 intake on my SC. PM me if interested.
chrisbalich 09-17-2021 05:10 AM
Originally Posted by Peter M (Post 11459784)
Idk if I'm quite ready to spend 1500AUD on adapters just yet.
I reckon I can have a local friend with a 4-axis make me something similar for much less and then be able to make more if the market is there....probably. ;)
PM sent!
