Dueller's Avatar
any tricks for removing undercoating....
....from fender wells?
Much of it came off with pressure washing but some patches are stubbornly hanging tuff. Don't want to pressure wash so hard that I blast off the paint.
Tried using heat gun but that seems to make it stick harder
Jim
1987 Carrera
2002 BMW 525ti
1997 Buell Cyclone cafe project
1998 Buell S1W: "Angriest motorcycle I've ever ridden."
Old 09-01-2014, 12:47 PM
Dueller's Avatar
Sorry about crap phone pic
Jim
1987 Carrera
2002 BMW 525ti
Old 09-01-2014, 01:01 PM
Dueller's Avatar
Jim
1987 Carrera
2002 BMW 525ti
Old 09-01-2014, 01:04 PM
Brew Master
cabmandone's Avatar
I used a product from Lowes called Black Jack. I think it's a citrus based asphalt remover. You can see how I did in my thread on this.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/797267-while-im-there-strikes-again.html
Spray it on, let it set a while then use some steel wool or scrub brush to take it off. It worked pretty well for me.
Old 09-01-2014, 06:04 PM
Air Medal or two
afterburn 549's Avatar
Freez it. A blast of CO2
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 09-01-2014, 06:08 PM
Shaun @ Tru6's Avatar
Project 73 911 R/RS -- Week 5
Project 73 911 R/RS -- Week 3
Project 73 911 R/RS -- Week 2
Tru6 Restoration & Design
Old 09-01-2014, 06:18 PM
chapo's Avatar
I tried aircraft paint stripper, orange stripper, heat guns, etc. the only thing that worked and was time efficient was a wire wheel on a 4 inch makita grinder . Not super stiff, be prepared to wear some of the wires. Eye protection, long sleeves required. Gloves up to you, they can snag the grinder. Face protection is a good idea. You can do both in a day. I did the whole interior of my 69, not a great way to spend weekends.
Patrick
Old 09-01-2014, 06:37 PM
irl irl is online now
irl's Avatar
Send a message via AIM to irl
I agree with the wire wheel, some have had success with a air stippler but I just sweat it out with the wire cup brush on a dewalt grinder.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 09-01-2014, 07:30 PM
Heck, I’m only 5 not 71!
targa80's Avatar
I used a heat gun with a razor blade knife attached to it. When the blade was hot and the heat gun heated the undercoating it came off like butter.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 09-01-2014, 08:04 PM
Dueller's Avatar
Damn clever, Pat.
Jim
1987 Carrera
2002 BMW 525ti
Old 09-01-2014, 08:19 PM
frankc's Avatar
It appears that you are attempting to removing some black tar-based undercoating that was applied on top of the factory applied (and lightly painted) chip guard/rocker schutz, and leave the original paint undamaged as much as possible. I removed all the tar undercoating from the bottom of my car one winter - exposing the original paint.
I found the best approach was the following sequence:
1. Heat an area about 1 square ft with a heat gun until you see the tar start to soften
2. Remove the bulk of the tar with a plastic scraper - some will remain in the nooks in the chip guard. My car was undercoated when new, so I found that it had a layer of cosmoline between the tar and paint in most areas which acted as a great lubricant when scraping off the tar to avoid damaging the paint. Plus, the cosmoline melts at a lower temperature than the tar, so this made the removal much easier.
3. Working in smaller areas now, heat the area again lightly and spray on citrus based adhesive remover
4. Use a tooth brush to loosen and dissolve the tar from the nooks
5. Wipe area clean (have plenty of disposable shop towels on hand)
6. Spray the area with citrus de-greaser (note - different than adhesive remover) and wipe down.
7. Once the panel is complete, apply a cleaner wax to remove any remaining tar.
I noticed that the tar did stain the paint in some areas.
Be careful at step 4. If the tar is not dissolving easily, apply more heat. If you are too aggressive with the brush, you will remove the thin layer of paint. For really stubborn areas, 3M adhesive remover can be used instead of the citrus, but be sure to have appropriate ventilation and mask.
The photo below of my floor pan shows Step 6 completed on the left, Step 2 completed in the middle, and the untouched area on the right:
An area of the floor pan after Step 7 (untouched area in background):
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 09-01-2014, 08:40 PM
Dueller's Avatar
Thanks, Frank, for the detailed instructions. Your results are awesome.
Jim
1987 Carrera
2002 BMW 525ti
Old 09-02-2014, 05:10 AM
Licensed User
Shuie's Avatar
Soaking it in WD40 might work. It's worth a try. You probably already have some sitting on your bench
Old 09-02-2014, 07:54 AM
Dueller's Avatar
Thought about that Shu....or maybe when pe blaster. I have 4 fender wells to do so I may just try all of the suggestions and see what works the best.
Jim
1987 Carrera
2002 BMW 525ti
Old 09-02-2014, 10:04 AM
scottb's Avatar
There was a thread awhile back about a guy having success with a multi-tool like this - Oscillating Multifunction Power Tool w/ Variable Speed.
Details here: Undercoating Removal - The Fastest Method Yet!
YMMV.
Good luck!
1984 Targa
Old 09-02-2014, 01:01 PM
Brew Master
cabmandone's Avatar
I'm tellin ya, I did what you want to do. Don't waste your time with ANY of the big box store citrus cleaners. If you can find the ZEP orange cleaner that asphalt companies use, that would be my first choice. If you can't find that, the Black Jack from Lowes is the next best thing.
Old 09-02-2014, 03:06 PM
