TheSt|G's Avatar
Door lock issue(oddness?)
Situation is basically this:
I have an ''85 3.2 coupe with the electronic central locking. Both the center switch and internal lock knobs work as designed. The passenger side door handle key slot can both unlock and lock both doors. The driver's side however can only unlock, it is incapable of locking both doors.
Thoughts?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 09-03-2014, 05:40 AM
twistoffat's Avatar
Sounds like a failing micro switch on the drivers side. Been there. Do a search on Door micro switch and youŽll find loads of info.
Old 09-03-2014, 07:32 AM
TheSt|G's Avatar
Perfect, that sounds exactly like my problem. I do wish I had remembered to do this before my massive door overhaul last Monday, but at least I'm familiar with it.
Old 09-03-2014, 08:07 AM
