Charles Freeborn's Avatar
Spacer for stock steering wheel
I have no complaints with my stock steering wheel, other than I'd like it to be 1-2 inches closer to me. Is there a spacer than will accommodate this, while allowing the horn and turn signals to work in their original fashion, or do I have to scrap it all and go with aftermarket?
Thanks,
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 10-14-2013, 08:48 PM
Rescuer of old cars
Arne2's Avatar
Charles, does your car already have the factory extended hub steering wheel? If not, replacing your wheel with the extended hub should get it an inch of so closer.
But note that the control stalks stay where they are, so spacing the wheels farther away will make for more reach to the signals and wipers.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 10-14-2013, 08:59 PM
Not that I know of. I'll have to research that one. Any idea what the part # is?
Stalks staying put is okay.
Thanks!
-C
1972 914/4 Race Car
Old 10-14-2013, 09:06 PM
The extended hub wheels have the extension built into the wheel itself, it is not a desperate part sold by Porsche. You have to swap the old wheel for the "extended" one.
JR
Old 10-15-2013, 01:45 AM
I installed the extended hub into my car a while back, there were two parts...one was a new, longer steering shaft which near as I can tell is no longer available, the second part was an aluminium disc that used 3 screws to attach to the bottom of the steering wheel itself.
Seemed like dramatic overkill by Porsche, but other than the pain of removing the shaft (about a day round trip) I do like the result.
I can dig for a p/n if you need it....
Dennis
Old 10-15-2013, 05:34 AM
The extended shaft does sound like overkill, but if you can get one the advantage is you can also replace the steering column bearings which should be getting old; my lower bearing failed at 250k miles and got all 'ratchety'.
BTW, I was able to remove the shaft and the bearings without removing the steering colum from the car using some pullers I devised.
Chuck.H
'89 TurboLookTarga, 365k miles
Old 10-15-2013, 05:58 AM
Dennis
Can you expand on that, with part #s and pictures?
I have NEVER heard of such an extension. There is the extended hub option for the steering wheel, that is indeed an alloy spacer that bolts to a specific steering wheel crush cage with 3 bolts. But an extended steering shaft???
Old 10-15-2013, 06:22 AM
KNS KNS is offline
I have the factory extended wheel that javadog describes, the wheel and extension go together and can't be swapped with other wheels.
Kurt
Old 10-15-2013, 09:09 AM
yayo_ayala's Avatar
GeorgeK, I am trying to do the same, adding an extension to the steering wheel. Before I go into the path of buying a new steering, were you able to perform the extension in your steering wheel?
Thaks
Old 09-03-2014, 10:49 AM
Yayo, see below. The black parts are the factory extended hub, the silver is the spacer I had made by a local workhop. These are from my 964, but the parts are the same for the 911.
Old 09-03-2014, 11:07 AM
J West Steering Eccentric Adapter
I installed this with a Momo wheel, really love it, brings the wheel in perfect.
Old 09-03-2014, 11:13 AM
Very nice, except this thread is about stock wheels.
Old 09-03-2014, 11:52 AM
86FlatSix
JQ911's Avatar
George, just curious on the silver spacer pictured above. I have been looking for a spacer with a 3-bolt pattern hub same as the OEMs. I have an Italvolanti Formel steering wheel similar with bolt pattern of the 930S steering wheel. How much did it cost you to make those spacers?
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 09-03-2014, 05:14 PM
Cost was about 80-100$ based on a basic drawing I made up. Local friendly machine shop did that for me.
Old 09-03-2014, 10:22 PM
yayo_ayala's Avatar
Thanks George. Interesting you were able to bring the wheel at the distance that you wanted. I have a base steering wheel, doesn't even have the extended hub, I am wondering if I can extend it?
Old 09-04-2014, 08:53 AM
