83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by wpgelb View Post
Looking at your parts diagram, the culprit is the rod shown on the top right...
If that is the one, you don't need an engine drop but you should shop for a new mechanic...
Who Will Live... Will See
Old 09-10-2014, 08:25 AM
Member 911 Anonymous
DRACO A5OG's Avatar
took car to mechanic who said he needed to replace both parts of joint (ball and socket) and some other bushings in the area. also said that he need to drop/lower the engine to get in there to do the work. as you would expect, the labor is several times the cost of the parts. any thoughts on this? if this makes sense, are there other areas to check while the engine is lowered/dropped?
WTF??? No, you do not need to drop the engine, the darn thing is on top of the engine near the manifold. You can actually reach your arm thru the manifolds and grab it.
'85 Carrera Targa
PCA/POC
Old 09-10-2014, 08:39 AM
Dueller's Avatar
I looked at mine...I suspect all you need is the little clip replaced at the bottom of the linkage to hold it in place. Hell some thin gage bailing wire wrapped around it would probably hold indefinitely for a temp fix
Jim
1987 Carrera
2002 BMW 525ti
1997 Buell Cyclone cafe project
1998 Buell S1W: "Angriest motorcycle I've ever ridden."
Old 09-10-2014, 08:48 AM
steely's Avatar
+1 For real
I edited my earlier post a couple of days ago to post a link to Jim's (DRACO's) tutorial - maybe you (wpgelb) missed it. Don't be afraid, that's what we're here for :-).
For the cost of the labor you'd pay the guy, there is a heck of a lot of little things you could do while you are in there.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 09-10-2014, 02:31 PM
JJ 911SC's Avatar
Originally Posted by steely View Post
... For the cost of the labor you'd pay the guy, there is a heck of a lot of little things you could do while you are in there.
And next thing you know it will look like that and you'll have all kind of room in the engine bay
Old 09-10-2014, 02:42 PM
Tags
dme , gas pedal
