-   -   Weltmeister Sway Bar Install (http://forums.pelicanparts.com/porsche-911-technical-forum/82829-weltmeister-sway-bar-install.html)
HarryD 10-03-2002 01:14 PM
I am getting ready to install a Weltmeister Rear Sway bar. As I am poor at reading directions but great at looking at pictures, could someone post a shot of their spring plates, showing where the replacement eccentric is installed?
Also, when I remove the existing eccentric nut, does this hose my alignment (that I just did)? Can I scribe the plate to get it located correctly and avoid the cost a an alignment?
TIA.
89911 10-03-2002 08:59 PM
Your alignment is held by the bolts on the trailing arms, so removing the aligment bolts will not change the settings. The Weltmeister bolt is actually a replacement for the bolt and should be tightened after replacing to aid it retention of the alignment settings.
