Price Check: 911T 2.4 engine and trans
Hey gang, just picked up a complete 2.4 out of a 73 911T along with the matching 915 transmission. Its been sitting in a barn for years and I'm debating over whether to build this for an early hotrod, or flip it. I'm 99% sure it will need a rebuild. What are these engines/transmission going for these days as "cores"? I haven't seen any pop up for sale recently. Thanks!
Old 09-08-2014, 07:55 PM
jittsl's Avatar
Unknown condition 2.4 T and tranny $3-5K
Laurence
1998 Specbox racer / 1998 Boxster / 1984 RSR tribute
1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa
1963 356B T6 Coupe / 1962 356B T6 Cabriolet
Current projects - 1955 356 pre-a Speedster / 1964 356C
Old 09-08-2014, 08:04 PM
LakeCleElum's Avatar
I have one I'm keeping to sell my 73.5 as "numbers matching" when I'm too old to change my own diapers.
Just a guess, but about $3K....Mag case engines can have expensive issues. If it's CIS that has been sitting, more headaches.......Would be worth more if in a running car and a PPI was possible.
.The 915, maybe $900 to $1,500 depending on condition?
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 09-08-2014, 08:06 PM
E Sully's Avatar
Like they said, mag case usually needs work. Is it a 7R case or earlier. If it has complete MFI it would bring up value, CIS not as much. If converted to carbs and no original intake things change again.
915 also, early had troublesome seal until later '73 with updated seal design that could be changed with out disassembly.
Does the engine rotate freely, any compression or leak down numbers, is magnesium corroding, etc. Pictures and a little more information would help.
Of course, if you find the owner of the original chassis, it would be worth more to him than other buyers.
Ed
1973.5 T
Old 09-09-2014, 05:24 AM
Excellent, thank you gentlemen. Looks like its worth a bit more than I expected... I think it will probably end up in the FS section after I look into it in more detail.
Old 09-09-2014, 02:34 PM
