911SC Hose ID
Would like to replace the three marked with blue tape. Are these vent hoses? What is the whet plastic container? Thanks!
White plastic container...
Fleabit peanut monkey
Container is called an expansion tank. Has to do with capturing fuel and vapors on overfill and or expansion within tank.
Hoses are for venting. Must be fuel grade.
1981 911SC Targa |
Thanks. So the container is similar to the charcoal canister in the engine bay, but without the charcoal. Any idea re: the part # on the hoses?
Looks like:
Upper left = N 020 359 1 Lower left = 999 181 189 50 Lower right = 911 201 287 01 However, on Pelican it shows this as NLA. Check the PET (where I got these)... Good luck. |
![]() If the fittings are 12mm and 8mm tube, I have this hose in E-85 Rubber but w/out the cloth braid. $10 for each, plus $6 for Priority Mail postage. Len at Autosportengineering dot com
