Identify Part Please
Hello,
Can someone tell me what the Black metal pipe is just below the two bolts securing the muffler?It seems to run into each cylinder from the bottom. Thanks
1978 RUF 911SCR Last edited by wacko; 09-16-2014 at 10:51 AM.. |
I believe if you click on the pic it will open up larger
It's the air injection system, which at one time was connected to the air pump. It appears to have been cut off and sealed at some point. Removal involves some dismantling of the exhaust system, something you may not want to do as hardware can break and you'll then be in a world of trouble. You can cut it into smaller pieces and avoid that hassle, but you still have to remove the air injector nozzles and seal the openings in the exhaust ports or seal the outer end of said air injector nozzles. There is risk involved here, too. I'd just leave it where it is until it's time for major engine work. BTW, your sump plate is 90 degrees out of position. The drain plug should be on the left (driver's) side of the engine.
The Cap'n |
76 911S Targa
Air lines for the smog pump? What year car?
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
76 911S Targa
Never mind. The Cap'n answered your questions.
It is a 1978 911sc row. The pipe/tube is broken. Can I drive it like this without causing any damage?
If the pipe is broken and the end has not been sealed, then exhaust gas will be expelled from the opening, as well as some considerable noise. I suppose it's possible that cold air entering from the pipe, after shut down, could affect the exhaust valves as well. I'd fix it correctly, if it were my car.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
I have tacked welded it together for now. Anybody have a part number?
76 911S Targa
Since it is not functional, I would remove it. Even if it were functional I would remove it. The spider is composed of two parts: the curved black pipe you see which was formerly attached to the air pump in the engine compartment and six nozzles which are screwed into the exhaust ports. Methodically soak the fittings with penetrating oil such as PB Blaster or Kroil. Heat gently with a torch and soak some more. I did this probably ten times over several weeks before removing the assembly. After this preparation the assembly will likely be easily removed. There are horror stories about breaking the fittings inside the cylinder head. Go carefully. The holes in the exhaust ports can be plugged with these:
PEL-BRC-02 found here: Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Thanks Targalid,
I think that will be my long term plan, I'm heading out this weekend for a short trip so I think my welding job will suffice until I can remove it and plug the holes |
10mm fine thread plugs the head.
Bruce |
