pete917's Avatar
Which way around transmission mount cup washers
I have the pressed steel type transmission cross mount (not the alloy G50 type).
Which is the correct configuration of the cup washes. One underneath and the other on top. I cant remember if they cup inwards or outwards.
Many thanks.
Pete
Porsche, there is no substitute!
911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv
Old 09-12-2014, 02:03 AM
Caledonian's Avatar
This way is standard )-( this way apparently stiffens the mounts a bit more (-)
How do I know? I read about it on here of course... I even recall some Porsche tech bulitin about the washer orientation as part of a cure for a gear shifting issue, but I can't remember for what models.
Old 09-12-2014, 04:31 AM
pete917's Avatar
That's interesting. I have put them on that way i.e., bottom one cup facing down, top one cup facing up. But I have also been told it should be the opposite and the cups inwards pacing over the rubber.
I dont speak German, but I found this and pic shows the cups facing inwards.....
It would be great to know for sure
Motorlager / Getriebelager - Porsche 911 G-Modell Forum / Kaufberatung von PFF.de
Pete
Old 09-12-2014, 04:36 AM
pete917's Avatar
Does anyone have a link to the tech bulletin? I have searched but can't find it.
Pete
Old 09-12-2014, 05:19 AM
kodioneill's Avatar
Pelican Parts Technical BBS - Powered by vBulletin
Some discussion on the subject.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 09-14-2014, 06:31 AM
Can I just undo and reverse the cup washers without upsetting anything? If so, I would like to try, and see if I notice any difference!
1982 911SC Wine Red Metallic
OMG I love this car!
Old 09-14-2014, 11:42 AM
83 911 Production Cab #10
JJ 911SC's Avatar
I read it too but if they are mounted "backward" might as well use a normal washer as 90% of the convex/concave washer is in airspace.
Who Will Live... Will See
Old 09-14-2014, 01:47 PM
kshafer1's Avatar
1979 911 SC Coupe
2000 VW Passat 1.8T
Old 09-14-2014, 03:30 PM
JJ 911SC's Avatar
Got to love the CYA note...
Old 09-14-2014, 03:34 PM
kshafer1's Avatar
Thus the reason for so much confusion!
1979 911 SC Coupe
2000 VW Passat 1.8T
Old 09-14-2014, 04:15 PM
JJ 911SC's Avatar
The drawing is not a true representation of the washer.
In the "new" configuration only the outer edge of the washer of the would touch the rubber.
Oppositely in the "old" configuration only a few mm of the inner hole would touch the rubber.
When you look at the CAT its even worse, good luck figuring which way its going...
But at the end of the day, these washer are like our Little League Baseball Political Correctness, it does not matter if you win or loose (convex or concave) everybody wins and get a gold medal
Old 09-14-2014, 04:54 PM
