G50 shifter washers
I'm servicing my G50 shifter and it seems PO put the washers that hold the assembly on the underside of the shifter between the tunnel.
On the picture shows that washers go on top of shifter between bolt's head. Can anybody confirm this please? Thanks in advance ![]()
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
Mine are on top, as per the diagram. The shift mount is adjustable fore and aft; if the washers were on the bottom they would serve no purpose, and the bolts on top would not tighten without wrecking the aluminum of the mount.
They should go on top.
Here is a pic of mine during dis-assembly before I serviced the bushings. ![]()
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Damn PO.
Thank you guys!!!
