Which way around transmission mount cup washers
I have the pressed steel type transmission cross mount (not the alloy G50 type).
Which is the correct configuration of the cup washes. One underneath and the other on top. I cant remember if they cup inwards or outwards. Many thanks.
Pete Porsche, there is no substitute! 911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv Last edited by pete917; 09-12-2014 at 02:14 AM.. |
This way is standard )-( this way apparently stiffens the mounts a bit more (-)
How do I know? I read about it on here of course... I even recall some Porsche tech bulitin about the washer orientation as part of a cure for a gear shifting issue, but I can't remember for what models. |
I dont speak German, but I found this and pic shows the cups facing inwards..... It would be great to know for sure Motorlager / Getriebelager - Porsche 911 G-Modell Forum / Kaufberatung von PFF.de
Pete Porsche, there is no substitute! 911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv |
Does anyone have a link to the tech bulletin? I have searched but can't find it.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Can I just undo and reverse the cup washers without upsetting anything? If so, I would like to try, and see if I notice any difference!
1982 911SC Wine Red Metallic OMG I love this car! |
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
1979 911 SC Coupe 2000 VW Passat 1.8T |
Got to love the CYA note...
Thus the reason for so much confusion!
The drawing is not a true representation of the washer.
In the "new" configuration only the outer edge of the washer of the would touch the rubber. Oppositely in the "old" configuration only a few mm of the inner hole would touch the rubber. When you look at the CAT its even worse, good luck figuring which way its going... But at the end of the day, these washer are like our Little League Baseball Political Correctness, it does not matter if you win or loose (convex or concave) everybody wins and get a gold medal
