Jbabic's Avatar
Question Undercoating?
Does anyone know where to get the undercoating within the enigne compartment in 77-78 911's? Mine has rubbed off and has come major scratches, I would like to reapply if I could just find this stuff. Thanks in advance.
Old 09-30-2002, 11:54 AM
Wurth USA; available in black, gray and maybe white(?) There is also a special gun used to spay it on. Then one needs to paint it to match car. Jim
Old 09-30-2002, 12:15 PM
scottb's Avatar
Harbor Freight also sells an undercoating gun that looks suspiciously like the one Wurth sells, but for a lot less money. Might be worth a look.
1984 Targa
Old 09-30-2002, 04:30 PM
Wurth SKS Stoneguard #890030 (black), #890031 (grey), #890032 (beige), #890033 (white); $20.50 for a 33.8 oz (1000ml)bottle. One bottle was enough to completely recoat a 911 fuel tank (all sides). Apply with Wurth gun #8911061 or #89110; gun screws right into bottle. I don't know cost of gun as I borrowed one from a friend. Spraying this stuff is messy (like flocking a Christmas tree) but it dries quickly and looks great (very OEM). One must clean the gun right away after use with soap and water. Call Wurth USA, Inc. (Ramsey, NJ) 800/526-5228 to find out which regional office to use, then at that office they'll put in touch with a sales rep. who can set you up an account. Cheers, Jim
Old 09-30-2002, 05:38 PM
Jbabic's Avatar
Talking
Thanks all,
I was on vacation, but now I can really enjoy myself. I was paiting over the existing undercoating, and it just didn't look right. fully appreciated.
Old 10-05-2002, 05:58 AM
Send a message via AIM to Oldporsche
Cool
Undercoating comes in the two paint varieties, solvent based asphalt type products and water based products.
Those that can be painted over, the latex's such as Wurth stuff mentioned. The spray gun from worth is made with brass parts so it won't rust from the use of water based undercoats. You can paint over these undercoats.
The Solvent based untercoats will probably bleed through a coat of paint.
You might consider some of the 3M undercoats also. They are available in the better auto parts stores and paint shops. American undercoats have come a long ways in the past decade.
Good luck,
David Duffield
Old 10-05-2002, 06:27 AM
