Nine11cab
Fan strap HELP!
Can anyone please tell me how to remove the fan strap on my 82SC as I just want to power coat it.
Old 09-15-2014, 05:34 AM
fred cook's Avatar
Fan Strap
Once you get the fan and housing out of the way, remove the distributor. To make it easier to reassemble, set the distributor at #1 with the engine at TDC. Then you will have to bend the strap a bit to get it to slide out of the slots in the block. Any paint finish will likely get some damage when re-installing the strap. You would probably be better off buying a new strap from PP!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-15-2014, 06:40 AM
