Stophos's Avatar
Front Fender Mounted Oil Cooler in 69S
Mounting the front oil cooler in my 69S and I think I am missing a bracket or something because the only two mounting points I see are the two on the tub that go through the vented cover and cooler. I do see there is another mounting point on the front side of the cooler but I see nothing to mount it to. What am I missing? Pictures anyone?
Thanks - Chris
Old 11-30-2014, 06:07 PM
HarryD's Avatar
If I am not mistaken, you have a dual battery set up. If so, the battery box is where the cooler goes.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-30-2014, 06:51 PM
Stophos's Avatar
Got it.. Thanks
Old 11-30-2014, 07:13 PM
Stophos's Avatar
Two tub bolts through the vented cover and cooler and one from the cooler to the fender bracket support bolt at the fender side. I just realized my cooler bracket was bent. Fixed it and all is good.
Thanks - Chris
Old 11-30-2014, 07:18 PM
78-911SC's Avatar
How about pics of the completion and bracket.
PJ
78 911sc Targa
70 911T
Old 11-30-2014, 07:59 PM
Stophos's Avatar
1969 911s Fender Mounted Oil Cooler
Pictures tell the story. Looks like I may have to loosen the fender a bit to get it in there though.
Old 12-03-2014, 05:46 PM
Stophos's Avatar
Oil cooler bracket mounts with 25mm bolt bolt and nut at bumper bracket.
Old 12-03-2014, 05:47 PM
