-   -   (http://forums.pelicanparts.com/porsche-911-technical-forum/830362-a.html)
Sergei (guest) 09-18-2014 08:12 AM
i want convesion my 911 turbo look 1986 transmission 915 change to tiptronic or G50 transmission??? es posible... tanks for respond.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 09-18-2014 08:12 AM
I'mnot sure.
- Nick
Dave Colangelo 09-18-2014 08:14 AM
G50 yes, but it will take some modification. To my knowledge it will bolt on to your engine however the G50 had a Hydraulic clutch so you will have to either convert the cable system to that or find a way to attach the cable to the G50. The shift cuppler and mechanism is also a bit different however since I believe the chassis remained the same though out you should be able to drop in a G50 style shifter with out any modifications in that area.
The tip transmission is a whole other issue. I dont know much about them but I would think that there is a lot of electronic work that needs to be done. Could it be done, most likely, would it be worth it/cost effective, no. The tip cars are really cheap in their own right. For the cost of the conversion you could find a nice tip equipped 911.
Regards
Dave
GH85Carrera 09-18-2014 08:26 AM
Anything is possible with enough money thrown at it. Ruf could make the conversion for you and it would look like the factory did it.
It would be a ton cheaper to buy a car with what you want.
ClickClickBoom 09-18-2014 08:38 AM
Different T-Bars and associated assys.
Quicksilver 09-18-2014 11:31 AM
More to the point...
You really need to cut out the torsion tube and put in one from an 87 or later G50 car. (hackity hack...)
Also I believe Patrick Racing does the short bell housing conversion on the G50 which can get you some more space.
