Help needed with brake pad identification
Can anyone tell me what year this pads are off of. The car started life as a 1969, but the calipers could be 1969 and up. I want to order new pads but no one can cross reference the numbers on the pads.
I can't get the pictures to upload. Front pads have these numbers on them 20011. 185. 164 11.351.940.0 B11063 KBA 60282 Rears PAG1D514FF |
The rear would be PAGID 514 FF.
do the fronts use the same size pad as the rears if so they are M/M if the front pads are bigger then they are S/M If you look in the Pelican brake pad section any of the M pads fit the rear, and if the f/r are the same in front too. If the fronts are bigger then any pads for S or A will work The latest pads have provisions for pad sensors which are not needed on a '69 but you can still use the pads anyway |
So the front and rear are interchangeable? They look to be about the same size.
The front Ms use the same 3" bolt mounts and pads as the M rears, the M front calipers use the bigger 48mm pistons as used in the A & S fronts, all the rear Ms through '83 used 38mm rear pistons |
Thanks for the help, it is appreciated
| All times are GMT -8. The time now is 04:25 PM. |
