Clock Gauge Diameter
I've got a dead clock in my 3.2 and am considering replacing it with something more useful.
Does anyone know the gauge diameter of the clock? (my car is unfortunately away and I can't measure it myself)
1986 911 3.2 Cabriolet "We all have a desire to create something that will show we were here. " Ferry Porsche |
Regis turd ab user
My '71 without the rubber seal is 80mm, I believe they are the same. Is yours a VDO quartz, I've seen many of those keep good time?
It IS VDO quartz and I'm sure it was accurate back in the day, but 28 years must have taken a toll on the mechanism. Thanks, BTW!
Regis turd ab user
Before you pitch it, open it up and dab some Deoxit 5 electronic cleaner/lube on the moving parts. It could be just a little corrosion causing problems. Don't spray it, it's hard to do a little bit and it will go flyin'.
I will give that a shot
